2 Jib Halyard Questions
Apr 6, 2011
21
Cal 1-27 backyard
I have wire to rope halyards and thimble for both. What are the instructions on how to put the thimble onto the wire? It seems simple, but I want to make sure it is safe.
Where does the jib halyard attach when the jib is stowed away? I do not have roller furling.
Thanks,
Chris
WayneH
Tartan 37 287 Pensacola, FL
No help on thimbles.
When I'm in the slip, I attach my jib halyards to the lifeline stanchions to avoid the mast slapping. I've got a ring at the base of my mast to clip the halyards to for sailing. So yes, I do move them to go out and put them back on the lifeline stanchions when I return.
Feb 6, 1998
11,767
If you have a thimble it gets the wire wraped around it and then the cable is swagged with the proper swaging tool. Usually wire to rope halyards are done with a rope to wire splice though so it can fit through the sheave..
