I have a 1984 Oday 28. I need to replace the 2-burner stove with a new Origo 3000 that happens to be the same dimensions. I mistakenly threw out the old metal insulating cabinet with gimbals along with the original 2-burner stove. The Origo replaces the 2-burner just fine and they sell gimbals that are small vertical rails that need to mount into a cabinet. I no longer have a cabinet - it is just an empty cavity now. I've contacted Dometic (maker of Origo) and D&R Marine and Defender Marine so far with no resolution other than to custom fabricate the cabinet. This is not my forte.
Does anyone have a cabinet from this model Oday that I can buy? If I have to build it, what materials do you recommend that would cover the open gap in the galley while also providing heat insulating qualities that I need?
