1994 Catalina 28 leaky transom shower
CFitz
Aug 4, 2019
18
Catalina 28 Canada
Just noticed that our transom shower has a slow leak. The water won't completely shut off when the water pressure is on. Both cold and hot handles are closed tight but it's still leaking out of the shower head. This might be a common problem? We are new boat owners. Just wondering if anyone has had the same issue and has any tips to fix this problem. Thanks
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Could be as simple as removing the caps off the water valve knobs and adjust the screw. If that doesn't work, take apart the valve and replace the O rings. If that doesn't work, replace the entire valve assembly from Catalina Direct, Replacement Boat Parts, etc.
Likes: CFitz
Catalina 320 Dana Point
There's usually an on/off valve on the shower head itself, that should stop the leak until you get the faucet fixed.
Likes: CFitz
