1990 H30-2 shore power breaker replacement
May 19, 2020
85
Hunter 30-2 Quincy
Looking for ideas on how to replace/improve the shore power breaker on my boat.
I apologize for the lack of photos but I'm not sure how much they would help.
My shore power inlet is in the port lazarette and has a round push-type circuit breaker right under (or maybe above) it. The breaker itself has failed and will not reset. I know there are no faults in the system, it's 100% a dead CB. It only interrupts the hot line which is not in compliance with current practices.
Any suggestions for how to improve this? I found a surface-mount CB enclosure from Blue Sea Systems that I think could work but it seems like a lot of extra wire is going to get run. Almost considering relocating the inlet to abovedecks but that might bring its own problems (at least I'd be <10' to the panel and could skip the circuit breaker).
Kind of open-ended but I'm trying to see if there's ideas I haven't come up with yet. Thanks!
JamesG161
Feb 14, 2014
8,111
Hunter 430 Waveland, MS
Per ABYC standards, first breaker must be within 10 inches of shore power inlet.
Jim...
May 19, 2020
85
Hunter 30-2 Quincy
Not trying to argue or anything but I've always heard 10 feet for shore power
"E-8.11.9.3 If the location of the main shore power disconnect circuit breaker is in excess of three meters (10 feet) from the shore power inlet or the electrical attachment point of a permanently installed shore power cord, additional fuses or circuit breakers shall be provided within 10 feet (three meters) of the inlet or attachment point to the electrical system of the boat. Measurement is made along the conductors."
From https://sbo.sailboatowners.com/downloads/Hunter_gen_41598472.pdf
JamesG161
Feb 14, 2014
8,111
From them...
E-8.11.9.1.2.1 if it is physically impractical to place the
circuit breaker or fuse at the source of power, it can be placed within seven inches (178 mm) of the source of power for each circuit or conductor, measured along the conductor.
Jim...
PS: My copy said 10 inches
From them...
Jim...
My understanding is that the seven inch requirement applies to on-board sources of power (e.g. batteries). Shore power requirements are explicitly specified as 10 feet in E-8.11.9.3 as BOSSailor pointed out.
My understanding is
AC circuits (ie shore power) within 10 ft
DC circuits (ie batteries) within 7 inches, but there are some exceptions.
Here’s a handy graphic to help (from Bluesea).
JamesG161
Feb 14, 2014
8,111
Just like the OP said.... his was under his lazarette, so is mine with a water resistant covering over the switch.
We have 2 - 30 amp shore power inputs.
Then you can run 10 foot to your AC panel breakers.
This from my real copy of the 2008 ABCY E-11 standard
But we do have a Genset on board.
Jim...
Jun 1, 2009
1,881
Hunter 49 toronto
Jim...
Jim,
I’d like to (respectfully) respond on a few issues here
Whomever did this wiring did a less than stellar job. Seeing as this is mains AC input, and is prone to fire, I’m going to lay it out, and hope not to offend.
The wiring is not professionally done, and the first glaring evidence of that is the $9.99 crimp tool.
These types of “punch crimps” are horribly unreliable. The ONLY way to crimp is with controlled cycle ratchet tools which spread the swags over the whole barrel portion.
These crimps give point pressure only, and will easily pull off. Worse still, they have high resistance electrically.
Also, these crimps are really poor quality, and the wire is corroded in the crimp. This is due in part to not having an even fully compressed crimp.
Purchase new crimps from Blue Seas, and a proper controlled cycle tool.
If the wire shows corrosion when you strip it, very lightly sand the wire till you get clean copper.
I’m not sure if this is original Hunter wiring.
Next thing, get rid of the screws & replace them with fresh Phillips head screws
You can tell these breakers have been worked on before, and it’s tough to get proper torque into slot head screws.
Plus, these are really chewed up
Be sure to use ring terminals with holes the proper size for the screws. This is critical, and is dangerous if you use terminals with holes way over-sized.
Hope this has been helpful
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
I bought my crimp tool from Mainsail. I have one for standard terminals and a different one for heat shrink type terminals
Fred
Sep 27, 2008
517
Catalina 28 mkii 745 Ottawa, Ontario, CA
If you are looking to upgrade your system... My insurance wants me to install an ELCI breaker. You may wish to consider this as well.
Jun 1, 2009
1,881
Hunter 49 toronto
Speaking of insurance and boats’ electrical systems, I highly recommend the Smartplug AC inlet. Especially for 50 amp systems.
No shortage of boat fires owing to twist lock connectors
Likes: Ward H
