Hello,
I need to replace my mast light deck fittings: 1) 2-prong male plug at base of mast is connected to wires that travel to the mast light and 2) 2-hole female fitting that is attached to the deck and is connected to wires from the battery/fuse block. The attached picture shows Item 1) on the top in the picture and Item 2) on the bottom in the picture (arrangement of items in the photo was by chance and not by design).
Please, can you tell me how to procure these two fittings or similar (and installed in a straight-forward manner)? It would be easiest if they fit the original 3-hole pattern. But, that is not absolutely necessary: if I must I will adjust to a new configuration.
Your suggestions are welcome,
Mark
Owner/skipper: Coral Rose
Mark
