1987 Catalina 22 Replacing Rubber Seals on Pop Uo Seat Locher Hatches.
Feb 20, 2016
153
Catalina 22 Palm Harbor
We are looking for some suggestions as to what material to purchase in the replacement of exterior Pop Up Battery and Fuel Compartment Seat Lockers. Catalina Direct has an expensive product: Hatch Gasket Black Rubber (catalinadirect.com) but not sure this product is rubber or if it has to be.
Want to eliminate boat wash down water leaks into Battery Seat Pop Up Locker particularily. The Fuel Compartment loccker pop up is less of an issue because it drains to the deck internally.
There appear to be challenges with removing the existing seal and cleaning out the trench these gaskets fit into. Any help with that task and preparation for the new gaskets would also be appreciated
Jan 4, 2006
7,462
I've seen worse. If the new gasket is maintained, it's good for the life of the boat.
If not maintained, maybe 10 years.
"Challenge" is putting it rather mildly when removing gaskets. @$^%&#* is a much more accurate description. Allow an easy 3-4 hours prep for EACH lazerette. Use razor sharp wood chisels that fit the trench (re-sharpen to fit the curve of the trench), acetone, lacquer thinner, sandpaper, Dremel with wire brush, and whatever else you can find that works. Use the usual precautions with strong solvents and experiment. A job like like this will not be a picnic but when it's finished, it's well worth the effort.
Feb 20, 2016
153
Thanks..............Got all the tools and the time. Right now I think I'll wait until next year. Want to enjoy before summer sailing on the Florida West Coast
Nov 21, 2012
800
Momentarily Boatless Port Ludlow, WA
Search for Trim-lok. I replaced the pop top gasket on my C22 a few years ago.I found good match for it on Amazon.
-na -NA Anywhere USA
@John Marrone
Catalina Direct knows your boat well. If not, call the Catalina plant In Largo Florida and ask for skip. Tell him Crazy Dave sent you. He may direct you to parts. I am a former Catalina dealer now retired
Feb 20, 2016
153
The Largo Fabrication location is a "JOKE" they don't call back, they sent all their parts not scheduled for boat fabrication out to Defender. I have toured this location and from a simple observation I have no idea how this location survives while starting to understand why CD is a profitable as they are. Kind of uncomfortable as to the longevity of this Brand...........................
That is why I gave you a contact whom to talk with. A year ago Frank butler died and the chief designer, Gerry Douglass, retired this year.
shank
Apr 20, 2016
125
Catalina 27 5231 Lake Champlain
Do you find anything from tri-lock or another alternative? I need the same thing for a Catalina 27. Thanks
did you ever talk with skip at catalina? if not, may I suggest Catalina Direct as they have been around for many years and found them to be helpful.
