Found the leak under the battery cabinet, The Port side cockpit floor drain that drains out the rear is leaking.
the sleeve that is in this opening is moving. There is no room between the transom and the deck to fit any threaded item to fix this issue
Caulked the gap created by the movement and less water is coming in the cabin storage area under the battery box. Is there a way to remove these sleeves and install a threaded sleeve into the access after the existing sleeves are removed. Something that can be butyl sealed and screwed thign against the interior and exterior face of the transom
