Anyone know where to source these
OK....do you call these jam cleats???
Thanks
Thanks
I would not call that a jam cleat, just a horn cleat, albeit a different looking one. Most have dual horns. Rather than locating one to match, consider a dual horn cleat..do you call these jam cleats???
Yes, that is the most common name.... a type of horn cleat that has a "pincher" base on one side. I have one on my boom for the clew reef line.... very streamlined and efficient. You can the open horn side to secure the tail when used with a winch as a sheet cleat. For the reef line, or any control line or halyard for that matter, the "jam" side faces the load source... the open cleat side faces away. You can hook the tail around the open end and "sweat" the line between cleat and load.... pull the slack in around the horn and snap the line into the pincher to hold fast. Finally, slap on a half hitch over the open end horn to secure things. On my boom, to keep the line positioned and secure, the tail is threaded through a hole in the base of the cleat and secured with a stopper knot.Anyone know where to source these
Thanks
How big do you need.....Its the desire to replace new stuff on our boat while making an effort to keep with the original look
So far have not found any big enough even in the new style to match
