Graymarine for a Cat 30
I swapped out the frozen Atomic 4 in my Catalina 30 with a Graymarine gas engine last summer. In the Cat 30, the engine is located directly below the main cabin hatch and the counter island with the sinks. After removing the cabinet and the main sheet traveler, I raised the boom with the topping lift and then used the main sheet blocks to raise the old engine up above the deck level in the hatch. Swing the boom over to the side and guide the engine off the boat as you lower it down. I found it easier with the lifelines off also. The replacement Graymarine appeared to be almost identical to the Atomic 4 except that I had to make mounting brackets to convert the vertical mounts to horizontal. (I'm afraid I don"t know how the engine is mounted in the Cat 27, but I assume it's similar). E-mail me with any questions, or if your in the Southern California area, my boat is in Marina Del Rey and I'd be happy to show you. psp1@recyclermail.com
