The boat never had a bilge pump installed. I found a purposely made passage between the bilge and the starboard berth bulkhead for a hose but it seems restricted as I could barely snake a tape measure through it. Has anyone done a fresh install, and what is the hose OD that I should be able to get through it?
Looking around the yard at other boats, it looks like most thru hulls are about a foot above the waterline on the transom. Does that seem correct for the 25?
Also, I replaced the thru hull for the head sink. It is at waterline and has no seacock. Is there any problem with backflow while heeling?
