I'm working on this!
The manual posted on the web is based on the 1977 vintage 22, still mostly aplicable to earlier and later years. The mainsheet will be different though, the 1972 model had a triangle mainsheet setup, across the stern, from memory of early 22s that I've seen it had a block on the aft end of the cockpit coaming on each side, block on starboard side (or was it Port?) had a camcleat attached. Mainsheet was tied/spliced to a becket loop on top of that block, ran up to a double-block on end of boom, down to block on other side of stern, back up to double-block on boom end, then down through the first block and camcleat.Forward hatch was optional on the 1972 22, Rudy would be able to suggest a suitable hatch, although you will need to contend with the curve of the deck.One thing about D&R Marine, it is better to give Rudy a phone call than to rely on e-mail!OH, yes...I am still working on turning that original O'DAY 22 manual into a booklet, like I did for the Widgeon and the Day Sailer II. Thanks to Rudy I got some great info to add to those manuals. I also have copies of the 1977-85 O'DAY 23 manual and the O'Day 25 manual. Stil lworking on the 1971-75 O23.
