19 centerboard
93lkn
Apr 15, 2012
1
hunter 19 lake norman
I'm looking at a 1993 hunter,water ballast boat. The centerboard is broken off. Where can I buy one and any place for directions?
-na -NA Anywhere USA
My friend you have a good rigger named Tim at All Seasons on Lake Norman who runs the yard and knows the hunters.
First the centerboard is made by Foss Foam and they are in Florida. Look up on the internet and you will need to talk with Bob. Tell him I sent you or mention Crazy dave condon. It is costly.
The only way for a novice is to let Tim lift the boat up. To take it off, there is a bolt at the base of the compression post plate. You will need to take off the cover plate to see it. when you take that off, you will need to wiggle the unit for it to come loose . Make sure you note how the line runs and put a tracer on it. Maybe time to replace that line is now and it is smaller one size below 1/2 inch.
If you need anything else, get my phone number from Tim.
Apr 20, 2012
8
Hunter 260 Bayport
My swing keel wasn't broken but I wanted to be sure the lines were in good shape. I decided to have the bottom painted and while it was in the sling, I had the lines replaced too. The crane is the biggest expense so I was able to save some money by getting both done at the same time.
