The Line 2 (aka shore power B) male connector and cables burned up pretty badly so I replaced the male connector with a new one and yet the same thing happened. This was after connecting both the Line 1 and Line 2 shore cables and running each side of the 110V panel independently that Line 2 burned up. Before this, I seemed to be able to run fore and aft AC units using only Line 1 and switching to A/B parallel on the panel.
Some past history for the sleuths...In the past, the windlass magnets basically melted. I had some high heat/fire problems with the inverter charger cables at a point where some past owner had installed inline connectors and finally, I just the other day, I had to replace some of the wires in the forward AC that were essentially melted and fused together. I'm pretty sure those things happened in the past when I had both Line 1 and Line 2 connected.
Now I'm only back to only running on the Line #1 cable with panel switched to A/B parallel in order to run only the forward AC unit and as little as possible demand.
A fellow cruiser has suggested is that the problem might lie in a cut or damaged line #2 neutral wire. Could this be the problem? My boat was recently bottom painted and they primed and painted over all the bronze through hulls. Where does the neutral terminate on a 2000 Passage 420? I've looked at the schematics but I'm no electrical engineer. Any advice would be appreciated.
Thanks.
Thanks.
