Asymmetrical Spinnaker on a Mac25 safe rigging assistance needed
Jun 10, 2024
348
Hunter 240 Okanagan Lake
I was suppose to be practicing anchoring; instead we flew an asymmetrical Spinnaker on our Mac25. The wind was light, very light. We were enjoying sitting and disconnecting but then I had an idea. Let’s hoist the dousing sock with the Jib halyard and see what it looks like. I attached the tack directly to the bow. I removed a very light length of line which was probably used as a tacker. I hoisted the sock and we ran the sheets accordingly. I pulled the line and raised the sock exposing the Spinnaker. It was quite stimulating. The sail filled then proceeded to twist and come down. We changed our point of sail and filled it again but it wasn’t stable. I looked up and witnessed the sail was twisted at the very top a few times. We played for a few minutes then doused it. I want to do it again lol. VERY SOON but, with it rigged better.
I would like to mount a block higher above the forestay on the mast for a Spinnaker halyard. I am unsure of what is best to purchase or how high I should go? I would also like to have a block on the foredeck with the tack line going through it and locked closer to the mast base. When I learn what I’m doing, I would be able to adjust the height of the tack and also allow the tack to come back to the mast for dousing. Again I am unsure of the hardware best to use. I will likely completely over build it all lol.
For convenience Amazon would be where I would order from. I have a length of Samson 10mm line I can use. I have a bail that I could mount on the mast but..... I would imagine there is a fair amount of stress on this setup. Also I’m thinking a clutch mounted on the deck by the mast would be best to lock the tack and another cleat on the mast for the sock lines? Any help, recommendations would be greatly appreciated.
I must also ask, I have a very loved crew, what is the safest way to quickly stop flying the Spinnaker? My thought, release the tack? The thought following that, the sheet will come flying whipping if it’s not winched and cleated. Maybe best to release the sheets then tack then safely bring the sock down?
Appreciate any advice. TIA
Jun 10, 2024
348
More reading more research. I have found an add a halyard kit from Blue Water Yachts. It even gives the recommended 18 to 24 inches above the headstay to mount it.
I have also learned best to use a lighter tack line as a heavier line will drag the sail down in light winds. If anyone is doing this I’d love to hear about your setup. I’m guessing if I am way off base someone will chime in. With the end of the season on us I’m very pleased we accomplished this. We will likely get out one or two more times and just use the Jib halyard again and make a simple tacker/tack pennant attached to the bow with a swivel snap shackle.
When we are successful I will post a picture.
348
No comments is a bummer but some are still reading. Maybe there is interest in my project. I haven’t made it out yet. Not from lack of effort though. New parts arrived, I am impressed with Blue Water Yachts, very quick to ship. I was a bit concerned drilling the mast but it went good. We now have 3 halyards on our vessel.
I do have safety concerns. If I could get a reply or two for confirmation I would sure appreciate it.
When I am ready to set the Spinnaker tack line up properly, is it ok to use a cam cleat or best to use a rope clutch? A cam cleat seems too light but a clutch seems over kill. Perhaps a small winch and cleat is all that’s needed? What do you think is best for my setup? We don’t go out in big wind. We are going to have a short tack line on a swivel snap shackle for now.
In an emergency, when/if I pull the tack line what will happen? In my mind I’m thinking the sail will go forward quite quickly pulling on the sheets? Is it quite dramatic? This is also my concern with locking the tack line and what to use to safely release. I am basing all my thinking on up to 600kg of pull.
Dousing sock lines I am just going to cleat on the mast.
Thanks
When the Asym is flying the is generally on a beam to broad reach, if the sheet is released the sail will blow down wind and off the boat. The sheet shouldn't be an issue if it follows the sail and blows off the boat. Do not put a stopper knot on the sheet! Once the boat settles down, pull the sock down over the sail, once doused retrieve the sheet.
A cam cleat should be fine so long as it is in a place where the line can't be accidentally pulled out of the cleat or become a trip hazard.
600kg of pull seems awfully high. In my younger days I would fly a spinnaker on a J35 with just a wrap or two around a winch. Same with the J24. On the J24 the winch was used more to get the sheet to a better position for the trimmer than for any mechanical advantage.
. ...When I am ready to set the Spinnaker tack line up properly, is it ok to use a cam cleat or best to use a rope clutch? A cam cleat seems too light but a clutch seems over kill. Perhaps a small winch and cleat is all that’s needed? What do you think is best for my setup? We don’t go out in big wind. We are going to have a short tack line on a swivel snap shackle for now.
I'm not keen on using clutches on lines that potentially need to be adjusted quickly. Assuming your tack line is led to the cockpit or cabin top I think a cam cleat would be fine. I'm not sure when we talk about a tack line, we are talking about the same line. I call the line, that attaches to the tack of the asym and adjusts it in or out, the tack line. It isn't a line I would look to adjust in an emergency. It is tightened for closer to the wind sailing and eased for more downwind sailing.
In an overpowered situation I agree with Dave that to depower the asym quickly release the sheet all the way (Meaning that the sail is flogging to leeward - if your sheets are long enough you don't need to lose them). You can gather up the sail like a curtain and douse or lower it. It would have no wind in it.
I'm not such a fan of dousing socks but others on this forum are.
Jun 10, 2024
348
Ok thank you guys. Tack line, front of the asymmetrical sail attached to the bow. My research has said detach the tack line in an emergency. Letting the sheets go seems safer. We will let the sheets go. Perhaps we know why the sheets are so long now.
To have an adjustable tack line for the different points of downwind sailing is now the goal. (Let the sheet go not the tack) Allowing the tack to come back while dousing too.
To be safe it sounds like a few blocks would be required to get the tack line down the side of the vessel and cam cleated out of the way. (Rope clutch not preferred for lines that need adjusting quickly).
Good to know I’m thinking heavier loads than needed. We are very much still fair weather sailors.
That said, I would attach a block to the bow. I would run our 6mm dyneema tack line through the block and up attached to the tack of the Spinnaker(Knot). I will then run the tack line through two small blocks or more down the starboard side of the vessel running it through the cam cleat to secure in a low traffic part of the deck. Then use the sheet in an over powered situation to drop the sail.
If I’m on track, I will likely choose an oversized block for the tack line to run through at the bow. Could someone make a recommendation for me for our 6mm dyneema tack line?
Thanks again guys, I really appreciate your replies. I will read them again and make sure I understand everything.
6mm dyneema does not really like being knotted. It’s slipperiness makes knots prone to slipping, and knots in dyneema reduce the effective strength of the line. A splice in dyneema is easy to make and much stronger.
Jun 10, 2024
348
More reading, a swivel block would be needed. 40mm ish. I see blocks from 40$ to $140 lol. I will definitely choose an oversized block.
Spin sheets are long, twice the boat length, because they have to reach from the clew around the forestay and back to the transom and forward to the winch with enough left over to wrap around the winch.
Jun 10, 2024
348
Yikes, I paid to have it whipped. I have zero experience with splicing. I will ultimately need to order a longer line now so I will consider that. Thank you.
Jun 10, 2024
348
This is interesting, I did not know this. So run the sheets outside of the shrouds and down through the “car” passing the winch and cleat to a stern mounted block and then back up to the winch. A long run would determine if cleated after the winch.
Thank you for posting this. We would have ran the sheets just back to the cleats.
No car. They go from the clew of the sail to the turning blocks on the aft transom - if you have them. And then to the winch if needed.
Judging by where you put the new halyard from your picture I am assuming your rig is fractional - the jib head goes to mid-mast not the masthead. I mention this because your asym can’t be that large. And if you are sailing in light wind the loads on the sail aren’t going to be that large. I predict that you may be perfectly comfortable trimming by hand having only one wrap on the winch. Of course you’ll want to be able to cleat the sheet to attend to other matters. I don’t expect a “Hair on fire” experience for you. Spinnaker trim is about not over trimming. Generally you want to get sail out away from the boat keeping it well “Ventilated.” Tell tales are of limited use. So it’s “When in doubt, let it out” situation.
Jun 10, 2024
348
Thank you for the clarification. Yes, we are a fractional sloop rig and you just gave me huge relief. We’re so excited to do this. Thanks again.
Jun 10, 2024
348
@Davidasailor26 I did some searching and reading on knotting lines. There is an impressive amount of strength lost. Pretty much 50%, yikes.
I think I should learn how to splice and whip lines. I’m a little concerned that I will destroy the small amount of dyneema line that I have. I will keep searching, maybe a new thread would be good. Thanks again for posting this.
Splicing braided dyneema is not hard to learn, and really pretty fun once you do. I had no splicing experience at all before I started, and had no trouble. Then I started looking for other fun projects and excuses to make things like soft shackles. The process and references I used are mentioned at Got a new sailing dinghy
Jun 10, 2024
348
That is quite the discussion, well done. I am intrigued for future use.
Turns out I have a dyneema core with polyester/dyneema cover. My very first eye splice on 6mm line. I had to try twice. Both times I made it through the locking Brummel, pulled the dyneema core back into itself. I was then able to return the cover back up to the eye. I had troubles after this pulling the excess cover between the eye and back inside itself. I think I went a bit short on the final but I do believe it will be strong. I’m happy. I will do it again for sure.
I applaud the acquiring of skills. Always good! But a tied knot with 50% in loss of strength for dyneema and other high strength cordage is still way strong enough. Nevertheless I like the clean shape of the spliced eye. No pesky tails to snag.
Ah, that makes more sense for a control line like a tack line. Splicing covered dyneema is something I haven't tried advancing to yet. Good on you for giving that a try.
Jun 10, 2024
348
What a day. Almost no wind to speak of but eventually we enjoyed enough to hit 2 knots. That took us out far enough to enjoy lunch. After that we started setting up to fly the Spinnaker. After watching a few you tube videos, I learned that many just cleat that tack line off. I purchased a Lewmar 50mm block for the tack and a couple of 35’s for the rear turn blocks for the Spinnaker sheets. Turns out our cleat is too close to the mount for the tack line block. I ended up using a bowline and a set length tack. We did use our splice :)
We were fortunate to have a very light breeze for the journey home; just enough to fly our Spinnaker. It was gently unorganized. Likely quite stimulating if we had a good wind, but we did it. I must improve my rope handling skills. More organization is required too. Extra cleats on mast and bow.
Great day that ultimately ends our season.
