New LFP House Battery
Apr 22, 2011
949
Hunter 27 Pecan Grove, Oriental, NC
Greg, I would go through the pages of both battery apps and see if there are any settings that are not the same. If that checks out, I would cycle each setting key on the misbehaving app.
Jan 7, 2011
5,707
Oday 322 East Chicago, IN
Thanks. There aren’t too many settings to mess with in the Humseink BMS app.
I separated the batteries today and am charging the batteries independently tonight, and see if they can both be brought to the same voltage. if so, I will wire them back in parallel and see if they stay pretty much equalized when in use.
I love the fact that I can see what the batteries are doing, but it might drive me crazy micro-managing them :facepalm:
Greg
Jul 23, 2009
917
I got back to my boat today. Over a week ago I adjusted the float voltage on the charger up from 13.2 to 13.4. The battery is now resting at 93% SOC instead of 66% at 13.2v. I'm reasonably happy with that.
I still need to add a fuse and strap it down. I did add a protective cap on the positive terminal bolt. The straps I bought are too short.
5,707
An update on my new LFP battery bank…
I had communicated with the mfg (Humsienk) and they asked me to independently charge each battery using a 14.6 v and 5 amp charge, and to leave it on the charger for a couple of hours. I did each one, somewhat unsure of what good it would do since the batteries shut off their CHG switch once they are at 100% SOC.
But I did as instructed.
I reinstalled the batteries yesterday and left them charging over night (fridge and a few other things are on, so there is always a small load on the batteries).
Got to the boat this morning, batteries were within .1 volt of each other, and both were discharging (sharing the load). :thumbup:
I took the boat out for a 3 hour sail, leaving fridge and other electronics on, including using the AP a bit. I was very happy to see that both batteries were at same voltage, both discharging and sharing the load! When I got back to the dock, and before turning on the new Victron charger, Voltage and SOC were identical on both batteries. This is what I was expecting to see.
If I were to do it again, I might opt for a single 200 or 300 Ah battery to avoid the paralleling issues, but if these now are “equalized” and stay close to each other, I will be very happy.
Greg
Jun 17, 2022
278
Hunter 380 Comox BC
View attachment 233372 View attachment 233373
Greg
All correct !
Lithium wired in parallel must all have the same state of charge before wiring them together... Ideally cycled once or twice as well.
Recheck individual cell balance every 6 months or more based on usage and separate, recharge and then recombine...
Lithium does not mean maintenance free....
Jul 23, 2009
917
Update
My WattsCycle battery in my boat has been doing great. The shore power hadn't. But my fridge stays cold and I'm not damaging lead acid batteries every time the shore power falis. I'm still not quit finished with the install yet.
On another note, I recently replaced 34 AGM batteries in my solar project with 2 WattsCycle 24v 314ah batteries. They are big boys at almost 160lb each. My biggest complaint is that the bluetooth has very limited range and the decimal point in the hours remaining, in the app, seems to be off by one place. Now that I can see real SOC I'm surprised at the amount of power 3 refrigerators, 1 TV, 2 blower motors (AHUs) and a dehumidifier use. It appears that they use about 24 to 32kwh daily.
  • Wow
