My 1980 O’day 25 has a pretty simple DC layout.
1- 4 Cabin dome lights.
2- Running Lights. Steaming light.
3- Will have anchor light.
4- VHF.
5- Compass light.
6- Will have cig lighter sockets and USB for accessories.
The current switch panel is stock and has 4 switches with push button breakers and is wired directly to battery.
The electric start and charging outboard is also connected directly to the battery (2 wires only).
No battery switch.
I plan to replace the stock panel with a 6 switch panel with lighter sockets, USB socket, power indicator LEDs and a 4 position battery switch. I am thinking 4 position switch in case I add another battery later this summer.
I will install a MBF fuse at the battery positive terminal to protect the wiring and a fuse block to protect the loads. Fuse block, terminal strip and negative buss bar will probably be mounted on a board in the lazzarete near the battery. I will run wires from the fuse block to each switch and then back to a terminal strip. I will connect the appropriate loads to the terminal strip and a neg buss bar.
If there is room behind the switch panel on the opposite wall I may mount the fuse block, buss bar and terminal strip there and hinge the switch panel. Opening the panel will then give me easy access to all the wiring and fuses.
Most all parts will be Blue Sea Systems from Defender.
I mostly day sail with some late evenings at anchor and then motor home. I will be switching to LED lighting as time and funds allow.
My questions are:
1. I heard that the VHF should be wired directly to the battery with its own fuse so if all else fails the radio still works. True? I would rather wire it after the battery switch so I don’t run down the battery and I do have a portable radio.
2. I plan to connect the OB to after the battery switch. Is this correct? I saw a thread where one person connected it directly to the battery.
3. I will research the correct wiring size and will follow Maine’s tips on connectors. Will the amount of wires on the panel flex enough for the panel to be opened if on a hinge?
I made some drawings of my plans. I’m open to suggestions and comments.
Thanks
Ward
4- VHF.
5- Compass light.
No battery switch.
My questions are:
Thanks
Ward
