Automatic Bilge Pump
25
Oday 27 Colton's Point, MD
I'm looking for a recommendation for an automatic bilge pump to install on my O'Day 27. Anyone have experience in this area?
Bill
Jun 29, 2010
1,287
I put one of these in my O'Day 25 last spring.
LINK
Got hose and some wire from West Marine, I think I got the switch from Amazon but can't find any info on that at the moment.
Got the thru-hull from Defender as well. Just have to get over that drilling a hole in your boat thing....
Good luck. :)
Jun 18, 2012
25
Thanks for the suggestion! Yes, I agonize over putting another hole in the hull. I'll keep it high and on the stern quarter.
Bill
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Bilge pump mounting
I remember seeing an article in Good Old Boat about bilge pumps. One thing they talked about was that raising the outlet higher reduces the pumping capacity of the pump. Just something to think about.
Brian
Bill
Jun 18, 2012
25
Re: Bilge pump mounting
I will. I've been thinking about eliminating the vanity sink and replacing it with cabinets & drawers. I could re-purpose the vanity hull-thru for the bilge pump.
ebsail
Nov 28, 2010
241
O day 25 Nyack. New York
I know this won't be popular but;
There are only 2 kinds of leaks
1) small- overhead or the like, or less than 5 gallons per day
2) large- hose lets go or the like 500+ gallons per hour or more
Then
If you have #1 situation and the pump keeps the visible water down to a gallon or less, then you won't know you have a leak, and will do nothing untill the leak becomes a #2 leak. Then the batteries go flat trying to keep up with this major influx and the boat sinks. Better to keep the float switch high or leave off the float switch entirely and just have the electric bilge pump wth a manual off and on. If you come to the boat and the floor boards are floating you will definitely know you have a leak. If you never see water in the bilge you'll do nothing untill the leak gets to #2 and sinking occurs since no known bidge pump wiill keep up with #2 for very long.
ruidh
Oct 1, 2007
227
Oday 23 Manhasset Bay, LI
I installed my automatic bilge pump with a three way switch. AUTO-OFF-ON.
It is OFF when I am off the boat and I operate it manually when I return. I sometimes put it on auto when I'm sailing so that the heeling can get more water to the pump.
