I do have a stern light that plugs into boat it's on a shaft about 4ft tall, but I am guessing I need one on mast. Running wires up mast is not a problem, do I just mount it to top of mast?
On a 17' foot sailboat I believe I would just stick with the K.I.S.S. Principle.Bill sanders said:I do have a stern light that plugs into boat it's on a shaft about 4ft tall, but I am guessing I need one on mast. Running wires up mast is not a problem, do I just mount it to top of mast?
Bill,I do have a stern light that plugs into boat it's on a shaft about 4ft tall, but I am guessing I need one on mast. Running wires up mast is not a problem, do I just mount it to top of mast?
A Fine example of the K.I.S.S. principle!These are the lights I use: http://www.duckworksbbs.com/hardware/electrical/il-560-211x/index.htm. Because of the infrequent use of the boat, I don't have an onboard power system. They are portable, you mount the base, and clip the lights on when you need them. They are LED, and use very little power from 4 AA batteries (I've left them on intentionally to see how long the batteries would last - I got 4 days continuous use before they got a bit dim, and about 9 days continuous before they went out completely). I have three - my bow light (red and green), a 120* white stearn light for when I'm sailing, and a 360* stern light that I use for motoring (I simply swap the two when I need to - they use the same base). I put a shackle on my all around stern light and hoist it upside down on the backstay about 2/3 the way up for anchoring. That way, it can swing without hitting the mast. Works great.
If you are on facebook you can go to the morgan group: https://www.facebook.com/groups/morganyachts/ and go to pictures and then to Morgan 24 folder and you can see the doors I made for mine at home out of a teak colored Azek (a pvc material, in face I replaced all my teak with this material it is maintenance free unless you want to clean and shine it. I am not sure how to post pictures here. Do not know how to find the URL. I used 1/4" clear plexiglas, and made 1/8" oak panels and some screen holders to be able to have privacy or to remove them.23 at bottom and 36 at top
let's see if this works?? I believe you can also go to the project folder on the Facebook morgan area I think they are there if my attachments here do not work. Huh! it worked, click on the photos to enlarge them. There is a special PVC glue for the joints but I used 2 2.5-3" stainless screws predrilled of course at each joint, Need a table saw Pretty easy project, ordered hinges which allow me to lift the doors out If I want.23 at bottom and 36 at top
