Lost a spreader, How unsafe is it to sail with only one?
4,062
no motor? - boats us unlimited tow...
move it away from the dock, then make the call, then you need a tow to the yard you want to pull it.
zeehag
Mar 26, 2009
3,198
the fitting on my mizzen spreaders was sloppy and making wobbly actions--i had to take it off and re do the welds and then replace--isnt a big deal--just dont stress rig with no spreaders. can be troublesome.
Aug 20, 2010
1,399
Oday 27 Oak Orchard
I have been in the process of reanodizing and powder coating my mast. Shipping from Rochester, NY to Charlotte, NC - 525.00 A new extrusion - 2994.00 no hardware. Ya really wanna risk it? Maine sail and the others have it right. That sucker is more than likely to bend in half and do you want to risk an injury or death when it comes crashing down? Lost one mast on a 22 several years ago and that is an adventure I don't want to repeat. Easier to get a spreader and have it installed with the mast on saw horses. Better yet upgrade them both at the same time.
Dec 20, 2011
101
Cal 28 Eagle River
Unless you removed the mount it will still be on the mast as it's only two stainless plates as far as climbing the mast all you need is a good step ladder as it's only 16 ft. Use the other one as a pattern. Recreate the plates if you need them.Just two pins hold it on & cotter keys.you may have to drop spreader lites if you have them ,But;it's easy!..Dale
Dec 15, 2012
8
cal 2-27 tampa
Dale. Thanks again for the encouragement. I did in fact drop the plates when up on the bo'sn chair and they made it into the depths. The pins holding those plates (with the little piece of rotten spreader that was left between them didn't seem like much to hold the rig taught but I guess some play is allowable / desirable....I def. appreciate the encouragement. I guess I'll be fashioning some sort of new plate using the opposite one which I still have as a template. probably going with wood again even tho many recommend the aluminum spreaders...simply for the fact that i'd like to avoid having to redo/replace/refashion the mounts-to-mast. I'll be doing this "up there" is it really 16 feet...seems a hell of a lot higher when up there. I believe I have the extra-tall mast option on the cal 2-27...it's HIGH! spreaders look to be without measuring right at halfway up. the entire story i'm spinning here is going to be all temporary. the whole boat eventually will be gone over, mast down, high and dry, etc. in a few months. Just trying to get her set up to sail the 20 miles to that destination. Can't say enough how encouraging and appreciated ALL of the advice given herein has been. Thanks for sharing your experience.
Ray T
Jan 24, 2008
224
Hunter 216 West End - Seven Lakes
I had a 1978 Cal 2-27 and it had aluminum spreaders. You might check into this through D & R marine. I had bought a new rub rail for my Cal through them.
Oct 17, 2011
2,809
Ericson 29 Southport..
Shoot man, if you're just going to move it twenty miles and then haul it, I believe I'd hire some power boat around there to tow it to the hill before I went to all that...
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
It seems odd to me to have wood spreaders on an aluminum mast. A Catalina 27 tall rig? ... If it were my boat, I wouldn't do anything less than buy new brackets and spreaders and do it right, never to be concerned about it again. It's a small investment for peace of mind. Use ss rivets for the bracket attachments to the mast. Simple, easy, not too expensive and why do anything less?
385
Harpoon 5.2 Honolulu, HI
Why are you even considering this? Don't tempt fate, just motor the darned thing and get it fixed. This is NOT something you want to Band-Aid, and I am actually a big fan of jury rigging stuff. You want to try and catch that mast if it comes down in your lap?
20 miles is nothing to motor, would probably be good for your boat.
capta
Jun 4, 2009
5,103
It seems pretty simple to me.
All you have to do is hit a WAKE under sail (or power, for that matter) w/o your rig being tight enough and you could lose it. You will not get a halyard tight enough unless it's dynema; polyester (Dacron) line can stretch 7%!
Do not make a very expensive mistake and it's down right DANGEROUS when a rig comes down around you!
May 4, 2005
4,062
you're NUTS! motor the entire 20 miles and live another day.
clearly you've not seen a bent mast or one fall.
the saying 'sometimes your purpose in life is meant to be a warning to others' applies here
Mar 1, 2012
2,182
I had a boat with a wooden spreaders- 50+ yrs old, still going fine. As long as no rot, no problems.
One tip- when you do put the new ones in, paint the top surface white, and varnish the bottom. White paint will last for years in the sun, and the varnished under sides will lket you inspect them.
But I sure as hell wouldn't try to sail a boat ANYWHERE with a spreader missing. I've been aboard two , under sail, when the mast came down- exciting!!
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
I'm kind of surprised this has gone into the 2nd page.
Please Don't sail without proper rigging or risk damage or injury!
Oct 6, 2011
678
CM 32 USA
Anything on your sailboat that is a major player, that is out of service, benches your boat till it is rectified.
No
Dec 20, 2011
101
Cal 28 Eagle River
Set of spreaders on Ebay # 11993360910 are larger then you need ,But would be easy to cut down to your size. Wood with hardwear..Dale
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
Had you asked "How can I safely SAIL my boat to a repair point without fixing my spreader first" the answers probably would have been different. Maybe something like: 'sail on reefed main only-no foresail and don't raise sail head above lower shrouds'.
Had to throw in my two cents after reading some of 'shoot your eye out' type comments but when it gets right down to it you could have paddled to it by now.
-na -NA Anywhere USA
Blesailor;
I have sailed for over 50 years and repaired many masts and boats as a former sailboat dealer. I have seen alot and read alot too. The best advice for you sir as it appears that you are a recreational sailor is to go ahead and bite the bullet and replace the spreader with one that is of the same material and length. Sailing without a spreader or one that is not the same deminsions and so forth can lead into mast failure. In two cases I recall but vividly one, the skipper and owner of the boat was concerned about the cost but did not heed the advice. The mast fell and struck his young son in the head. I attended the funeral which was tragic and sad all due to the father wanting to save a few pennies.
Make shift or nothing done will in many cases hurt someone. Please fix that problem. If your mast was kenyon isomat, contact jim culibert in charlotte, nc with charleston spar. If a Dwyer mast, contact Bob at Dwyer Aluminimum. If not, contact Ken or Jean at Seco South as previously suggested.
dave condon
