My Cal 25 has a 20 gallon stainless steel fuel tank that stored diesel for an engine that was removed and replaced with a 2 cycle outward. I am considering using the tank as a fuel tank for the outboard. Any comments on why I should or should not?
Good suggestions and also check to see if there is still a ground on the tank and if not put one on and make sure it is vented to the outside.Don't forget to vent the bilge. The old diesel tank probably did not have any sort of passive or active venting. Gasoline fumes are heavier than air and will settle in the bilge, Before converting the tank you should install a blower system with a switch near the helm so that you can activate the blower prior to starting the engine.
Take a look at most any large powerboat today and you will see a similar system. All modern gasoline powerboats are required to have an active blower system that can be activated prior to starting the engine to ensure the bilge air has been vented and to prevent the possibility of an explosion or fire due to gathered fumes.
Just be careful, gasoline greatly increases yoru chance for fire or explosion and in the enclosed space of our sailboats and bilges this is not a good thing.
