fuel fill
Blitz
Jul 10, 2007
715
Seidelmann 34 Atlantic Highlands, NJ
Got a new perko (chrome plated bronze I think) fuel fill to replaced exactly the current fuel fill deck plate on my boat. It's the type that I need to fit a barbed fitting on the underside to the current fuel tank hose. Can this be Marelon or must it be bronze? Currently looks like gray PVC with barbs ground off.
Thanks
higgs
Aug 24, 2005
3,715
Nassau 34 Olcott, NY
Marelon is resistant to diesel so why not? It certainly will not cause any galvonic corrosion.
capta
Jun 4, 2009
5,008
I would highly recommend that you go with the bronze one. I do not know for sure, but the plastic one may not hold up if you ever want to remove the hose after some years. Getting hoses off hose barbs can be difficult and require quite a bit of force at times.
higgs
Aug 24, 2005
3,715
If you have to get the off in the future, you can always easily replace the barb if it gets damaged.
higgs
Aug 24, 2005
3,715
Chances are you will never have to remove the fill hose. I think it really doesn't matter what the fitting is made of as long as it is not damaged by diesel fuel. Even then, since it is at the top of the filler, it will not be subject to a lot of diesel. The pump nozzel will most likely go deeper than the fitting so it will only be subjected to the fuel when heeled until you use enough fuel to keep it clear. Don't overthink this.
Beneteau 323 Annapolis MD
I think that mixing metal and non-metal fitting is asking for trouble. They have a different reaction to heat and cold expansion/contraction. Stick with like materials.
Hunter 34 Alameda CA
Agree with Ron. I used to design clean water systems for the hitech industry. When we would join metal to plastic pipe we always used a flange on each with a gasket or o-ring between them. There is a 10x difference in coefficient of expansion between plastic and metal. On a hot day a tight fit between the two could crack eventually.
Blitz
Jul 10, 2007
715
Thanks all. Yes, that's what we do - everythink things...
I was thinking a bronze fitting but was a little worried about any reaction between the chrome plated deck plate and the bronze. thoughts?
Separately would sealing the threads with Teflon tape be ok?
Neal,
No reaction in our lifetime between those two. Besides they need to be immersed in seawater for that to happen. Teflon tape is good. Then you can take them apart again easily.
Allan
higgs
Aug 24, 2005
3,715
I think there is a tendency to overthing things on this site. Bronze or Marelon isn't going to make much difference.
Oct 17, 2011
2,809
Ericson 29 Southport..
Am I wrong in thinking that the fill should be grounded? I know diesel doesn't spark, blah, blah, but a recent survey had noted on the report that it should be grounded.
I do NOT know, but that thought just came upon me..
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
My survey this year called for the fill to be grounded- which it wasn't at manufacture
Jan 15, 2012
20
Dyer Dhow, Cats Paw 10 ft, 12 ft Montpelier, VT
I know that this is a little late, but here goes.
1, Even though the Forespar catalog says that the ball valves, seacocks and fittings are NPS not NPT according to an email I received from Forespar this year what is printed in their catalog is incorrect. With the Forespar NPS fitting you may be able to get a few threads of the barbed fitting on the fuel fill but at significant structural cost.
For those of you looking at Marelon ball valves and seacocks, the only barbed fittings that will work correctly are Forespars.
2. TheForespar tail piece is simply Dupont Zytel, 70G13l BK nylon (AKA Marelon). It's resin base is Duponts nylon 6/6, a nylon resin that absorbs a significant amount of moisture and, when it does, looses a significant amount of strength and swells. I think you'll find it hard to get off later on.
3. The critical issue is the difference in thread pattern. A male NPS thread pattern starts and ends with the same thread size throughout. It's designed just like a regular bolt. It's a pretty sloppy thread and depends on compression if bottomed out and a lot of pipe sealer. The NPT female thread starts with the same size thread as the NPT but tapers down so that after the first two turns the NPS thread is simply too big to accommodate the NPT thread. Not a very substantial connection.
4. Nylon is quite resistant to fuels, which is a good point. However, it does have a serious moisture problem.
5. The bronze fitting is overkill, but it is the ideal option.
6, Because there is most likely little chance of impact, my second choice would be a glass filled nylon fitting. I know of one manufacturer who molds NPT threaded fittings made out of the same material as Marelon. I believe that you can get them from McMaster-Carr (http://www.mcmaster.com/#standard-nylon-barbed-hose-fittings/=kupn1y).
