For the last two days I have been going through the boat preparing for our trip to the Bahamas, Eleuthera and Exumas Islands.
I'm tired and still only half way there....
Pulled the chain and rode out of the locker. Marked the chain every 15ft and cleaned the anchor locker.
Removed the propane bucket from the starboard lazertte(SP you know what I mean). Removed the two 5lb tanks that have lots of rust on the bottom. Have ordered from Sailboatowners two fiber glass 10lb tanks. Will cut and add 6 inches to the existing bucket to hold the new tanks. Measurements says they will fit. Pictures of this will follow.
Refrigeration system is toast. Compressor failed. So I removed the Alder-Barbour and evaporator. Will be installing a new system Frigoboat in the next couple of weeks.
checked proper shaft alignment, not problems found.
checked the impeller and found a broken vane which was wedged in the exhaust port side, was able to remove it. Installed new impeller.
Cleaned all strainers.
Shower sump box has a broken input connector. So that will need to be replaced.
