What is this device on my fresh water system?
1
Hunter 27 Lake Lanier
Hello All,
I recently purchased a 1978 Hunter 27. The PO installed a pressurized freshwater system and I cant figure out what this 3" PVC elbow is used for. The ends of the elbow have been reduced and house a 1/2" male fitting. The entire device is sealed. Therefore, I do not know what is inside of it. It is connected to the water pump output hose in between the pump and a one way spring/ball valve. Thanks for any replies.
7,745
Alden 50 Sarasota, Florida
from your description and the picture, I'd say it is a crude version of an accumulator tank.
Dec 16, 2006
353
Hunter 25.5 Cayuga Lake, NY
Maybe it's a crude homemade charcoal filter? Does it rattle when you shake it?
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
Hello All,
Home made expansion pressure regulator.
Oct 2, 2008
3,815
Pearson/ 530 Strafford, NH
Hello All,
Here's the one we installed (upper right hand shelf), your's is just as good and a bit cheaper.
All U Get
Gunni
Mar 16, 2010
5,937
Likely filled with activated charcoal - those end pieces will screw off. Can't be an accumulator, there is no bladder or provision for an air space.
You don't need it.
Nov 6, 2006
10,253
If installed with the "hump" upward (nipples below) it will hold a little air, maybe enough to quieten the pump and let it cycle less.. ??
Jul 1, 2012
155
Catalina C22 Georgetown
Maybe the PO's local hardware store ran out of 1/2" elbows, and he had to make due with what they had in stock???????????
Jeff
Sep 29, 2008
195
Hunter 33.5 Carlyle Lake in Central Illinois
Have you got Rube Goldberg's old boat?
