hunter 28 coastal vs offshore
17
hunter 28 Manhattan
i'm planning a cruise from nyc to va beach about 30mi off coast.
at the end of AUG'12.
2 sailors and a rookie. planning on around the clock each way with 1 night stop over at va beach.
on board;
fractional rig, bulb-wing keel (3'-9" draft),
12gal diesel. 16hp Yanmar. FWC
Main (2 reef) + 130 Genoa furling
Hand held floating VHF with DCS and internal GPS.
Fixed VHF
Registered MMSI number for DSC.
5" GPS mounted in cockpit.
Tridata: Depth finder, speed and autopilot=which is useless
Flares, fire extinguisher etc
2 batteries, 2 anchors (main: 14lb fluke type, ½” nylon rode 250ft, 14ft chain)
10w solar panel and radar reflector to be installed.
PLB and Viking life raft for 4 people (rented).
at this planning stage my question IS HOW MUCH OF A ROUGH WEATHER CAN A HUNTER 28 TAKE?
wind speed?
wave ht?
wave period?
thank you.
764
Hunter 376 Pensacola, FL
Provided the rigging and sails are all sound, the boat will be able to take much more than the crew, who will not be enjoying themselves very much in anything over 20 knots of wind or six foot seas.
Have plenty of bail-out stops identified just in case.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
Your boat sounds reasonably well equipped, but the question is how well equipped is the crew (mentally and physcially)? As noted previously, the boat will probably be able to stand up to extreme wind/wave/weather conditions better than the crew. That said, you clearly realize that your boat isn't a blue water cruiser and has certain limits and capabilities. If you have sailed for some period of time, you probably know these limits better than anyone else. Plan to keep a keen eye/ear out for developing bad weather conditions and take precautions early be that reducing sail or running for a port along the way. I assume you have a MOB plan and the gear to deal with such an event. I assume you all have harnesses and the boat will be rigged with jacklines. I assume you also are aware of the big shipping lanes along your route and that even with radar reflectors, some of these ships may not see you so you'll need a constant look out. In the end, you seem to have a good boat and capable crew and this is not a particularly difficult coastal cruise. Plan to have fun....albeit carefully.
Dunham
Jun 21, 2012
33
Hunter 33 Island Yacht Club
We have a Hunter 33 and took 23 knots of wind, 10 foot waves for about 30 LONG minutes. As someone mentioned above, the boat can take a heck of a beating but the weakest link is it's crew. We were drained emotionally, phsically and mentally (keep in mind we are new sailors) and had been sailing already for 4.5 hrs. Make sure your crew is prepared.
Jun 12, 2011
17
hunter 28 Manhattan
Thanks for the answers.
Rigging and sails are not bad, standing rigging has no defects all stainless anyway, however the split up V backstay is bit thin but not sure how much load is coming to these, its a 1x19 stainless wire rope, 1/8" thick, breaking strength is 2100lbs each, and the are about 75deg to each other anyway looks a little thin. Here something interesting last season when i took the boat to winter storage and took the bimini canvas out i noticed the railing that rests on the V backstay had chaffed up one of the legs to a point where 12 of 19 strands were broken, i dont think i had more than 10kn winds towards to the end of summer but it held up.
Will have jack lines and harness and a plan to duck in to a port in case of bad weather. will be watching for other ships.
I wish i bought a blue water 34fter instead of this one.
Thanks again.
May 28, 2009
764
It all depends on where you think you're going to spend your time. A true bluewater boat can been dark and cramped and not very comfortable if you actually spend most of your time dock sailing or cruising the bays and sounds.
If the standing rigging is over ten years old, it needs to be replaced. Otherwise I wouldn't recommend taking it (or any boat) anyplace that you couldn't swim back from.
xcyz
Hunter 376
Um, so I have to ask the reason that you need to be 30mi off the coast? What's preventing you from hugging the coast while you make passage or is it just for the adventure? I sail out west so I'm not familiar with the east coast but 30mi out does seem a bit far for such a light boat.
I also didn't see any mention of radar, are you intending to cross shipping lanes or encounter spots of low visibility where it would be needed?
Make sure your SeaTow renewal is in early..
Jun 4, 2004
844
Hunter 28.5 Tolchester, MD
I've sailed a deep keel (5'-2" fin keel) 1986 28.5 version since new, and would plan that trip with several stops; planning for typical 60 NM per day. Check out the Jersey Shore and Maryland shore inlets and I would question the long run from Ocean City, MD to Virginia Beach as I don't recall a decent inlet along that stretch. We did the Cape May to Virginia Bay Bridge Tunnel in an overnight shot on an O'Day 34 including some storm conditions that I would not have wanted to do on the 28.5. Suggest you look at reasonable weather windows, as my issue would be how long anyone would want to deal with 6' seas in a shoal draft boat.
Jun 12, 2011
17
hunter 28 Manhattan
I actually intended to go to miami last year, after 3mo of owning the boat and that much experience too, replies here made me change my mind,
Alan said "...We wish you well but in a few years you will begin to see just how foolish a decision this is." well he was right, last month i did a 6day cruse to shinecock bay and back, nothing went bad but things settled little more.
i appreciate all your replies...
RGDavis, s sauer:
well i dont have to be 30mi off, lets say 15 is more logical i guess, link below is a buoy about 15mi off the coast, waves do get up to 6ft some days, more than half of july around 3-4ft. with 8sc period which is good i think.
http://www.ndbc.noaa.gov/station_page.php?station=44009
i do not wanna deal with 6ft seas more than 2-3 hrs. at a time
i do not have money for radar right now, would be nice to have.
robertsapp: why would you replace the standing rigging after 10yrs, fatigue is the only thing that comes to my mind? is this done all the time?
looks like it will make more sense to go to ocean city first then come back, maybe to newport sometime in sept.
thanks a lot.
May 28, 2009
764
Your standard stainless steel rigging with swage fittings generally corrodes from the inside out. Typically, saltwater gets into the swage fittings and begins to corrode the internals of the connection. The advice to thoroughly check your swages for cracks or discoloration really doesn't help much, because the fitting can lose the majority of its strength from internal corrosion long before you see anything noticable on the outside. Your first indication that something might be wrong is when a shroud suddenly parts in a 20 knot gust. It is generally recommended to replace your standing rigging every ten years. You might be able to get by with longer if you sail exclusively in fresh water and haul the boat over the winter. If not, and your rigging is older than that, well, you're pretty much relying on blind luck at that point. Consider it just part of the cost of owning a boat, just like haulouts and bottom jobs.
Nov 8, 2010
11,386
With absolutely no disrespect intended, here is my simple rule.
If someone has to ask perfect strangers if THEIR boat is ready for a particular voyage, then it is very likely THEY are not, irrespective of how the boat might do.
When a person can confidently answer that question themselves, then they are ready.
jtm
Jun 14, 2004
314
Hunter 28.5 Dataw Island, SC
if you decide on a more inland Course B or C - you might want to consider overnite/shelter at Myers Hole just inside Barnegat Light- turning quick south just after passing the lighthouse to the anchorage.
Another would be Cape May inlet/canal. There an anchorage just inside and after the inlet's southern turn. for tie up and umbilicals there Utches Marina just before and to the south of the formal canal bridge overpass-
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
After cruising the east coast this summer in our 41, I would not go off shore in anything less than 37'. To each his own. You will get knocked around and it will not be fun.
Where did you go and what was your experience that led you to this conclusion?
Jun 4, 2004
1,087
Up and down the east coast from the gulf of Mexico to Long Island Sound. Some of the Sounds and bays can be worse than the ocean. There are all kinds of conditions awaiting and you cannot always wait for ideal conditions. Like I said, I was glad to be in a 41' and not my old 30'.
Dec 14, 2003
1,450
Jackdaw's point is very valid and Jim McCue's suggestion are good ones. You could go from NYC to Sandy Hook, then hug the coast towards Cape May, with Manasquan, Barnegat, and Atlantic City being there as escape inlets if things turn bad.
Don't forget that if you are 30 miles out, you need at least 6 hours to come straight back to the coast, more if you want to reach an inlet (unless you're directly abeam of that inlet).
If you make the run to VA Beach from Cape May, you'll be crossing very busy shipping lanes going across the Delaware River, then you'll be on a stretch of coast with no good inlet to speak of until you get there.
2 sailors and a rookie means almost no rest as the rookie cannot be left on watch alone.
1 night in VA Beach won't be enough to get the rest required to tackle the return trip.
As others have said, the boat can endure a lot more than any crew member can. Your plan doesn't provide for escape ways and waiting for a favorable weather window if need be.
As Jackstraw put it, I don't mean disrespect, but I'd pass on the opportunity if invited. And I have sailed my 34 offshore to Labrador, the East Coast of Canada, and also south to the Bahamas. Solo.
My suggestion is: Re-plan the trip, re-consider the routing, and revisit the crew arrangement (rookies are OK but you have to have enough experienced people to cover them).
That being said, I will also tell you that nothing ventured nothing gained. So the idea is to properly choose the crew, assess the risks, prepare for the worse (and expect it), build a plan with escape options en route, and then go !!! Good luck !
17
hunter 28 Manhattan
Robertsapp,
i see other stainless steel parts that are exposed to salt more than the standing rigging and no sign of corrosion, boat is 1993 make. a swage corroding from inside out would suck, i'm sure someone took some of them apart and saw this with their eyes and not guessing, so i'm inclined to take your word. but i'm not sure what i'll do about it other than a through inspection.
Claude & Jim McCue,
all of the plan is being reconsidered constantly, Cape May, Manasquan, Barnegat, and Atlantic City... can we add Ocean City?
route will be approx 15miles off. major shipping lane crossings will be avoided at dark. working on the crew.
Jackdaw,
only a fool would take your comment as disrespect, i appreciate it.
before reaching to "being ready" you have to "get ready" this thread is part of that process. i can not get anywhere reading about getting to places or screwing around in /around NYC.
fortune favors the prepared mind and game favors a move.
cheers guys.
May 28, 2009
764
Robertsapp,
You appear to be unfamiliar with the material properties of stainless steel. Anything you can visually inspect, oxygen can reach, and the chromium in the stainless steel reacts with the oxygen to form a passivating layer that protects the underlying metal. The problem is in areas that oxygen cannot reach (like inside swages, for example). Stainless steel is highly susceptible to a form of corrosion known as crevice corrosion, which occurs in an oxygen deprived environment. Without the abilty to interact with oxygen, stainless stell isn't much better than plain iron, and corrodes about as fast. So naturally all the pieces you can see look fine - they're exposed to oxygen in the air. It's all those places the air and your eyes can't get to where the problem is occuring. And I assure you, it is occuring, because all rigs will fail due to corrosion and stress given enough time.
Google stainless steel crevice corrosion. And here's something from an article I found online from a marine surveyor:
Time to Replace?
What is the expected "life span" of a rig before it should be replaced? Some authorities suggest 10 years for replacement. All of the problems above were with rigs that were more than 10 years old. But, we see some rigs at 15 years or more with no apparent problems.
There are too many variables for a simple answer. One of the most important variables is the type of stainless steel alloy used. Type 304 is often used because it is initially somewhat stronger. But, Type 316 stainless, which has 2% molybdenum in the alloy, is much more corrosion resistant.*
Where the boat has been makes a difference. Stainless deteriorates faster in hot salty tropical waters (TX summers and pollution). Usage makes a difference. Again, one authority suggests replacement after one hard leg of a round the world race, or a couple of seasons of serious offshore racing. Rarely do we as surveyors, or you as buyers, know for sure where the boat has been or how hard it has been used.
Without more definite information, the position we take is conservative. If problems such cracked swages, broken or pitted wire, etc. appear, we feel it is time to replace the entire gang. If a rig is more than 10 years old, it should be carefully monitored for such problems, and consideration made for the likelihood that replacement will be necessary in the near future. Even in the absence of problems, replacement of a rig more than 10 years old should be considered before embarking on major offshore passages or extended cruises.
J. Stormer, Marine Surveyor
Jun 12, 2011
17
hunter 28 Manhattan
i was unfamiliar, now i am. thank you.
so once the rigging is replaced is there a way to prevent crevice corrosion? similar to external zinc or painting the wire rope and inside of swage before the swaging maybe..
i read that insulation may or may not be good, it may trap and increase corrosion inside.
here is another link i found that was useful
http://www.corrosion-doctors.org/Forms-crevice/crevice1.htm
calculation example on the next page is particularly interesting, i bet the 10yr can be calculated reasonably using these formulas. well i guess one has to factor in the % loss of friction inside the swage too.
