Jib Halyard on Oday 22
25
Oday 1972 22' South Watuppa pond and Narragansett bay
I have a rope/wire jib halyard on my 1972 oday 22 that has seen its better days, do I need to stay with rope/wire or can I just go to all rope. All i am doing is cruising with it so i dont think this should be an issue but just want to make sure.
Jan 14, 2010
18
ODAY 22 LAKE ONTARIO, NY
Jib Halyard
You can go to an all rope halyard, they make lines specifically for that application. You may have to change the sheave at the top of the mast if it is not big enough for the new line.
Jun 2, 2004
1,957
Oday Day Sailer Wareham, MA
Since you sail on Watuppa Pond........ give Rudy a call at D&R Marine, he is "just up the street" from you and can set you up with a new, all-rope halyard and determine if you need to replace the sheaves.
Jul 8, 2012
25
just saw rudy last week to get some stays hes a great guy. The main reason I asked is a have a family member that used to work for NE Rope and have enough sta-set to rig the boat twice lol
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
All you need is 5/16" Sta-Set X for the halyard just as long as it fits through the sheave you're good to go. If it doesn't fit the sheave I would would change the sheave. Personally I don't like wire/rope for anything on a boat and I'd do away with it if I had it.
I bought two 5/16" halyards off Rudy a couple of years ago and did the eye splices for the head shackles myself. I also replaced the Jib halyard block on my mast which entailed having to cut a larger square hole in my mast to get it to fit. My mast has internal halyards.
Jul 8, 2012
25
I only wish i had internal halyards i hate the external on my 22 but i replaced it with 5/16 sta-set and so far soo good!!
