Hi everyone,
I have a Hunter 290, and the refrigeration unit has not worked since I bought the boat last year. I have done some minor troubleshooting, but still can't figure out what's broken-- It simply does not start, no matter what I do.
I'm considering replacing the whole thing. Does anyone know if there's enough space between the hull and the back wall of the ice box to install one of these?
http://www.defender.com/product.jsp?path=-1|406|10789|86418&id=323775
I'd check it myself, but the boat's in Florida and I'm in the Middle East for the time being.
And, just for those in-the-know, here are a few of the troubleshooting steps I've taken:
- There's voltage at the compressor, and I've run jumpers directly from the battery to the compressor to eliminate the possibility of corroded wiring.
- I've bypassed the thermostat, and still no start-up.
- I've heard that there's a fan circuit that must work on some models, but haven't tried to install (or bypass) one yet. There's no fan attached to my unit.
- I've also spotted some small cracks on the evaporator plate, so I suspect that it's actually a refrigerant leak (and a low-pressure cut-out in the compressor).
Ultimately, though, it doesn't run, and if the cracks in the evaporator are the culprit, it's going to take quite a bit of work to replace it. May be easier/cheaper in the long run just to replace it...
Thanks for any and all advice!
