JIb that will partially roll
Pearson 26W Marblehead
has anyone come up with a Jib that will partially roll and still keep its shape?
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Yes. The sailmaker builds a luff pad, made of foam, into the luff of the sail to do this. Mine is set up for two reefs. It should also be reinforced at the reef points.
Jun 17, 2007
402
MacGregor Mac26S Victoria Tx
Virtually all sail companies have foam luff panels that are sewn into the sail, parallel with the luff. As the sail is rolled up, the added thickness helps the sail to maintain it's shape, up to a point.
I recently ordered a Hyde genoa that have the panels. Mine came from Judy B / Hyde sails: http://www.judybsails.com/
Jun 9, 2008
1,860
- -- -Bayfield
Actually North uses rope luffs for furling headsails, just FYI, and not foam, which is a Bainbridge product. Both work fine.
Apr 22, 2009
342
Pearson P-31 Quantico
Correct me if I am wrong but are some of the earlier and now older mid-70 Hood furlers only useable in two positions, that is, all in or all out?
