redacted . . .
After having rebuilt probably 500+ engines in my life . . .
do a compression check . . .
check distributor for rotation. . . .
see if the pistons go up and down ...
check valve lash adjustment . . .
You know there is fuel getting in the motor so I'll not go there.
Fuel . . .
Good luck, Ray
Ray,
Thank You!
We are scheduling the compression check
Distributor rotates.
Pistons, at least two and I will eyeball all, go up and down ...
check valve lash adjustment . . .? How and what is this?
Fuel, I am going to prime the fuel pump using the "v-shaped handle" to ensure I have no fuel problem. But I am very sure, right now, it is not a fuel pump issue.
I do not want to say anything like, "I spoke to Ken at Moyer Marine and he said . . ." but I think we know that Ken and the rest of the guys at Moyer Marine are more interested in doing what we need to do rather than what one might foolishly do. So, where I to talk to Ken and say, I think my engine is dead and I need a whole new engine, he would probably say something along the lines of, well, lets see what the problem is.
No vacuum means no compression and if that is in all four cylinders, you proabaly have a cranking excessively moisture issue that has stuck the valves open. Rather than a new engine, you probably need new valve something or others and new valve something else or other. So, you probably need to spend a couple of hundred buck vice buy a new engine.
SOOOOOO, I am thinking, stuck valves.
And above, there are some others who suggested the same and some possible remedies. We will see.
Thanks for the reply!
Many Thanks for the Reply, actually.
Robert
