Anyone out here installed a Icom 802 on a Hunter 356 or 36? I will be purchasing the Icom kit from Gary at Dock side radio this April.. I have the 356 without a backstay and the 36 is it's close brother as far as boat layout. My port side transom has solar panels and wind generator installed so I need (probably) things to the starboard side.
I'm interested on where you installed the antenna tuner, what did you use for an antenna, RF ground. Did you install a dyna plate or use something like the KISS system.
HELP....
HELP....
