Hunter 25.5 Hairline Crack
37
Hunter 25.5 Monroe Harbor
Last weekend I noticed a small amount of water in the bottom floor area directly above the keel. I soaked it up with a rag thinking it was from when I was washing things and spilled some water. The closer I looked I could see a very small hairline crack directly above the keel (see pics) that is developing water. Over the course of a couple days it amounted to approximately a cup of water. When the boat was in dry dock I filled in any areas where the keel meets the hull with west systems epoxy prior to coating with interprotect 2000E, 6 coats. Perhaps there is a pin hole or area that is leaking.?
I can seal up this crack from the interior for now but is this a major issue I should be concerned with???!!! Any help is much appreciated.
37
Boat is a 1984, Hunter 25.5, fixed keel, with outboard motor. Let me know if you need any further info or photos. Thanks for your help.
Sep 6, 2011
14
Hunter 25.5 Fort Worth
Hi JKCMBOAT, I also have a 1984 25.5 and had a similar problem last year. I had water seeping straight up through my keel bolts (or so it appeared). I assumed that water had found a way up the keel bolt shafts and that I had a major problem. I began inspecting every through-hull fixture and discovered that one of my transducers was leaking right around the threads. I could only detect this because I got a light and a piece of paper towel on a stick and was able to get it just a little damp around the transducer hole. A quick glance at it and it looked bone dry but in fact a tiny amount of water was traveling from the transducer threads across the boat underneath the layers of fiber glass and coming up around the keel bolts. I cleaned and tighted the transducer and after a few days the keel bolts stopped leaking and have never been wet again. Hope this helps.
Dec 24, 2011
37
Dcfleming,
Can you help me understand exactly where these transducers are you are speaking of? If you have any photos this will help to. Many thanks.
Dec 24, 2011
81
Hunter 33C Chesapeake
Dcfleming,
The transducer is what the depth sounder uses. There's one on the left in the middle picture.
