So I finally made it to Triple Play this weekend. It is an alternate year, so I just had to bottom paint the waterline, leading edges and any bare spots. Of course, I got a late start and we had plans for the evening so in the remaining hour I had I went to work trying to remove my water tank.
There seemed to be quite a gap between the hull and the flat sheet of plywood on top of the tank so silly me, I thought I would cut it with my sawzall...bad idea...that fiberglass tabbing is TOUGH and I couldn't get the tip of the saw to bite. Then it did. Then the oops happened. I could see daylight. Through my hull. Not good. Clearly the sun had addled my brain somehow. Luckily it is a small hole (see the bright dot in the center of the photo) above the waterline in the boot stripe. JB Weld to the rescue.
I KNEW I had the wrong tool for the job and I persisted so I have nobody to blame but me. I knew I should have used my vibratory Dremel saw, but didn't bring it or the extension cord. I was a bit manic when I packed...unsure exactly what I could accomplish...so I really didn't bring everything. Plus I was thinking I would just take my circular saw, set it to a shallow depth, cut most of the plywood out and then just "cut around the corners" with the sawzall. I clearly wasn't thinking about how the confined space and size of the battery pack would limit how far into at least two of the corners I could cut.
Oh well. I was trying to get a big ticket neglected maintenance item off my to do list, so my heart was in the right place. Too bad about my brain though.
It is really going to be fun pulling that tank out. I hope it fits down the passage!
