1976 Newport 17’ with 1000lb capacity Load Rite trailer. No rust on trailer.
Starting to have second thoughts on buying this boat. I went into it knowing the possible issues but I figured for a thousand bucks (boat and trailer) and cost of a motor I could sail it like it is for a season to see if my wife and I still like sailing.
Now it is time to get it wet the issues seem bigger.
I could have spent more on a boat in better condition but we didn't want to invest that much in a "beginner" boat. Plus I like doing the small things like changing out a fitting, replacing the lines and sheets, small stuff like that. A couple of what I thought were small issues are crunched fiberglass around the mast step plate and some cracks at the top of the motor mount. I had visions of the mast blowing over or the motor dropping off so I took it to a fiberglass repair shop. Estimate is about $1000 if the motor mount cracks haven't let water into the wood and it starting rotting. Then more to fix that.
I know the iron swing keel will need to be dropped sometime. It is rusted and shows sign of spalding. (right term?)
The good news is there are no other cracks or even large gouges in the hull or top side. Just some minor spider web cracks. We did check it with a moisture meter and the hull appeared to be very dry.
Now I am worried that I might be sinking more money into it than it is worth.
Am I looking at it wrong? When fixing up an old boat do you or can you judge investment against return if you sell it?
I am not concerned about esthetics. I just don't want it to break down on us.
In one thread Chris told me to get some oars and take it out and enjoy it. Wish I could but I keep having these thoughts that the structural stuff needs to be done first and I don’t go to the Safe Boating class until the 28th.
I am going to a ASA101 course in May.
Am I overthinking this? Worrying too much? Is this normal with boats?
Appreciate your thoughts.
PS I attached photos of the mast foot damage and motor mount cracks.
