Matching stain
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
I had to replace a small section of my teak and holly floor - real thing not plywood. It is tough to find, and expensive, but I finally found what I sort of needed, but the teak is brown while the original floor surrounding the patch it a reddish teak. Any suggestions on how to blend the two?
Aug 29, 2010
6
Oday 272 LE Island Heights, NJ
You could take the old small section to a paint store to try and match it. If you get something close lightly scuff sand the new piece and restain it.
RichH
Feb 14, 2005
4,773
Try exposing the bare teak to direct sunlight, covered with a thin wrap of saran, etc. Sunlight exposure will often 'develop' the teak color towards reddish. May take a week or more for the color development.
If not to the 'hue' you want, then consider to stain it using VERY diluted 'washes' of stain ... and 'work up' to the color/hue you desire. You'll not want to do this 'tinting' all at once but allow the teak to fully dry to be sure the final hue is what you want. Sometimes to get the color 'correct' you have to add teeny amounts of analine dye to the wash. When 'washing' dont 'soak', just wipe on/off with the diluted mix and 'build' to the color/hue desired.
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
How much extra teak do you have? You will need it to try and figure out the right finish.
You will want to check out a wood finishing website for tips and ideas. Its allot of playing around, but worth it! Don't let someone tell you it cant be matched. It can it just takes time and $ if you aren't doing it.
Here s a link to a very common stain site http://www.minwax.com/
Good luck and keep notes when you start mixing stains to get the right color.
Please don't go to the paint store and have them try and match it. They can't! If you go anywhere go to someone that refinishes fine furniture. They know what they are doing and will be glad to help you.
11,772
I would not suggest using a stain. The finish will look like, well, a stain. Instead try Watco Danish Oil in Cherry or Red Mahogany. They have other colors as well but I have the most success with these two matching aged reddish teak. You want it to come in just under the old stuff so that as it ages they blend well..
Take some scrap pieces of the new wood and apply different Watco colors, then the finish you have on the rest of the floor, and see what matches best.. Be sure to let the Watco fully cure before over coating. You can get very close with the Watco and not make it looked botched...
higgs
Aug 24, 2005
3,738
Watco oil: If I do the oil, then I can't varnish oveer it, can I?
RichH
Feb 14, 2005
4,773
No you cant varnish over top of oil, even 'resinated' oil (oil + varnish mixture). You most certainly do not want 'oil' on a sole as it will be a potentially hazardous 'skating rink' when wetted.
With tinted varnish you will be able to 'follow' the color hue as needed at a later time when/if the color saturation/hue changes due to oxidation and UV exposure; and, if the color/hue becomes too strong you will be able to sand down through the build-up to 'lighten' if necessary in the future ... and without sanding into the wood or veneer.
Dec 2, 2003
480
Catalina C-320 Washington, NC
I used Minwax red mahogony stain on our old Cal T-2 and it was a perfect match. Buy a small can of that and of dark walnut. Then try it on a piece scrap, if it is too 'red', add dark walnut 1:3 in seperate container and try that...adjust until you like the color.
Note: The stain color should be a shade lighter on raw wood tahn the finished appearance if you did not strip the entire sole as the final color will darken when you apply varnish. Test on scrap before final application.
11,772
Really? That's funny because I have been using Watco tinted Danish oils to match teak for well over 20 years and never once had a single problem. I was on a boat just last week that I did about 8 years ago and it blended / aged in to be not discernible from the old "real" teak. vs. the plantation teak we often get today that is an entirely different color. Most of these matches are then varnished.. Please tell me when I should be looking for the failure.. I'm guessing at year 25?;)
Watco dries and can then be over coated, done it far too many times to even count. You do want to let it fully cure and this can take 3-7 days.
RichH
Feb 14, 2005
4,773
Oh really? Tell me 'one' oil finish that doesnt 'darken' or oxidize with age. Im sure those surfaces that you did 20 years ago are now oxidized towards becoming as 'dark as the inside of a mausoleum'. :)
11,772
Oil finishes darken with age as do most all woods.. Does not mean the matches don't blend well for many, many years and adhere just fine to one another. I've not had any "dark as a mausoleum" matches if anything they stay lighter longer than I would like because I don't go for the dead nuts match to allow for natural darkening...... I find it amusing when I find out somehting I have been doing for over 20 years now "can't work"...;) I don't generally recommend something unless I have actual experience doing it and i have quite a bit of experience using Watco to match new teak to older teak and as stated no "issues"..
11,772
OK here's a trivia question there are pieces of teak that were replace in this cabinetry. One piece was done 6 years ago and another was done 2 years ago. Both were blended with Watco to match the old teak.. Which pieces of teak had to be replaced?
RichH
Feb 14, 2005
4,773
Maine your skewing the argument to obtain/match your own 'results'.
First of all, if you didnt know exactly what the original finish (oil based or urethane) on those panels you'd simply not be able to slap on Watco and expect the same results in color match. That you KNOW that these panels 'were' originally finished with Watco makes it a no brainer for use of the same and to expect a barest minimum difference in color match.
Second, the discussion is Higgs boat, where he probably doesnt know even the nature of the original finish (oil based or urethane, etc.). I would guess that he doesnt want to strip out the entire remaining finish and then recoat the entire sole with Watco. He simply wants a close match to what he has, which is probably an unknown finish at this point but quite probably a urethane. Watco, unless he re-does the entire sole, simply isnt going to be an 'easy' solution in Higgs case for his SOLE.
Do you really use or recommend Watco for soles????? ... very hard to believe.
Jun 1, 2004
8,351
wow.... I knew this was gonna happen, eventually, and here it is.
higgs
Aug 24, 2005
3,738
Maybe my post was worthless, but the responses sure weren't. Thanks to all.
11,772
I did not know what the "original" finish was nor do I on other boats I work on unless the factory can tell me, the owner knows or other folks in an owners association. Supposedly our boat left the factory in 1979 with a "teak oil". No one knows or recalls what it was in 1979 as apparently the company went out of business and they switched finishes. I simply took a pic of that cabinet because I happend to be working on the boat getting her ready for tomorrows launch. I can take some of customers boats too. I have examples from Ericsons, Sabre's, Cape Dory and others...
Again I had no clue what the original finish was only what product the previous owners put over the original finish back in the early 80's.
I made a test stick out of the scrap new teak and used Watco and many other finishes to try and get the closest natural looking match. Once the pigmented products were cured I put the same product over it that the PO's used as an interior finish and the did a side by side until I decided on which one looked the best and I thought would age out the best.. This is how I normally do it tint an actual piece of the new teak, with multiple products, let cure and then finish with what ever the boat has as it's top finish coat.. Watco Mahogany, two coats, was the closest match on this project. On some Sabre's & Cape Dory's I have found Watco Cherry or a mix works well..
The Watco was never suggested as a "finish" just to get the tone of the wood close to what he has now, then to over coat it with what ever he currently uses. I don't recommend Watco as a final finish for a sole nor would I recommend varnish for this. I have over coated Watco with everything from a urethane to polyurethane to Cetol and spar varnish. You just need to let it fully cure and it takes a top coat quite well..
If his sole is simply oiled then no, but if it already has a polyurethane or other top coat then he can use the Watco to bring the new piece into the tone of the old then top coat once fully cured... Even brand new teak boards rarely match up color wise. I usually bring an old piece with me when buying teak to get the closest color match. Some is really "blonde" and some red and some in the brownish family.. I have tried many stains from many manufacturers and they look like stained teak. The Dansih oil looks like naturally aged teak. I like that look better.
Higgs can obviously do what he want's I merely made a suggestion that has worked for me many, many, many times and I know it "can", you said it "can't".....;)
Never have as a top coat, never would, but for blending new teak to old, when a top coat will go over it sure, I've done it.....
This is actually what I said:
The "then the finish you have on the rest of the floor" is the key part in determining that I did not recommend Watco as a final finish just a tone matcher......
Bob J.
Apr 14, 2009
775
Sabre 28 NH
Good discussion going on today.
MS,
When I look at the pic you posted, the teak has a kind of blonde apperance that seems to be in line with what we see on newer boats today. The teak I bought for the bulkhead replacements is darker. I did buy marine grade teak from Goosebay but it's nothing like the stuff they sold 30 year ago. The rest of the woodwork on the Sabre is almost a deep orange color, some from age & some from what the PO used for oil.
I tried the Watco oil on a couple of sample, (watco oil is great stuff) but the "finish"
doesn't come close to matching what's on the boat. I came up with the "gunstock" stain from walking thur a Home Depot one day. It is almost a perfect match with the existing wordwork in the boat.
So why do you think the Watco isn't giving me the same result? I've only tried the cherry flavor so far.
Bob
