Lubricating Sail Slugs
127
Hunter 33.5 Northern Neck, VA
I have been told a good method for lubricating sail slugs is to use 10W-40 motor oil. You add some to each slug as you raise the main. Anyone out there have any experience or comments regarding this method?
Thanks
Paul Cyre
Sep 29, 2008
162
Morgan Out Island 33 Pompano Beach
I dont think I'd like to get motor oil anywhere near a sail. Why not use silicone spray. Bob
7,695
Alden 50 Sarasota, Florida
That's about the worst advice I've ever heard someone get. Oils will attract dirt and make the problem much worse not to mention softening the plasticizers in the slugs.
Buy a can of McLube Sailkote which will last you "forever" and work well.
Aug 28, 2007
127
Thanks!! I thought oil and sails don't mix. How is Sailkote applied. Do you spray each slug or is it applied to the track? If you apply it to the track how do you do that?
Thanks
Paul
Jun 21, 2007
2,118
When I spray McLube Sailkote on my slugs (~43' luff length) the sail seems (well almost anyway) to just want to fly up on its own with just hand pulling on my halyard. And the effect of spraying the lubricant is quite long lasting.
An alternative, but not nearly as good, is dry silicone based spray lubricant from your local hardware store. I've found that it's not as effective as McLube, but a great improvement over nothing. The hardware store dry silicone spray does dry gunk free.
I agree with the other responses--- don't use anything petroleum based. Dust and gunk will accumulate that will thicken/gel in the mast track. And over short order cause more resistance than doing nothing. ... Not to mention the staining to your mast and sails and possible damage to the finish. Visualize your garage floor back in the days when dripping oil from a car's oil pan or crankshaft bearings was the norm.
Just an aside on the ease of raising sail topic. In case you don't do it, when the sail is raised, the boom angle should be set higher than the mainsail's natural hang level by either using the topping lift; or by extending the rigid boom vang if that's your setup. To achieve this, also slacken the downward tension of the mainsheet and boom vang. Without the boom raised, the weight of the boom is transferred to the mast slugs pulling out away from the mast in the slug track (i.e. the aft direction) = a lot more friction. After the sail is raised and the halyard tensioned ,then you can let the boom hang to it's natural level for the sail trim conditions you want/need.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
While I like and use McLube Sailkote, at the start of each season (which was yesterday for me!), I polish my plastic sail slugs with some very fine emory paper (i.e., 1500 grit) to ensure any burrs are smoothed over. It also helps to make sure your sail track is free of dirt, junk, spider webs and the like.
May 24, 2004
7,215
CC 30 South Florida
I have a flat piece of metal with a ring on one side which fits in the track. Ill wrap a piece of towel around it and soak it with Sailkote. I'll attach the main halyard and a downhaul line to the ring and will slide it up and down the track a few times. The first coule of times just to remove dirt and grime from the track and then a couple of times just to lubricate. I find that doing this twice a year is enough. I also spray a little Sailkote on the slugs for good measure.
Aug 28, 2007
127
Benny
Can you post a picture of your high tech luber/cleaner that you use.
Thanks
Paul
Jun 21, 2007
2,118
Is it OK to use Sailkote to lubricate the insides of the winches?
I would say not. Sailkote is much too light weight a lubricant to accommodate the high stresses inside a winch. Best to use the winch manufacture's recommended grease/lubricant. On the Anderson Winch website a few years ago, I recall that they warned that use of an non-approved grease could result in "injury or death". (Just maybe a bit of hyperbole to sell their winch lub?) But any case, doesn't hurt to follow the manufacturer's instructions.
Also, it's not just a spray some new lubricant around type of project. It's a very good idea to first dismantle the winches and remove all the old grease and grime by soaking the winch parts in diesel fuel, paint thinner or the like and further helping with an old tooth brush or the like. Then brush on a light coat of the recommended lubricant. An internet search will help with tips for winch dismantling, cleaning and re-lubing.
Here's a link to a thread a couple of years ago on the type-of-grease subject. Particularly note MaineSail's comments ... he's a guy in the know.
http://forums.sbo.sailboatowners.com/showthread.php?t=120184&highlight=winch
Mac
Jun 7, 2006
436
MacGregor 25 KEUKA lake NY
WD 40 is not petroleum based, it is a fish oil base. We used to use it for catching walleye fish, just spray it on the lure.
Jun 1, 2004
8,323
Absolutely NOT...... invest in a winch maintenance kit.... Lewmar makes a good one... and follow instructions. FYI, winch grease on the gears and bearings.... lightweight oil on pawls.
Oct 26, 2005
2,057
- - Satellite Beach, FL.
I haven't and will not be trying it but would bet that WD40 would leave serious stains on the sail.
Jun 21, 2007
2,118
Also use the McLube on your nylon zippers. BrianW
Yes, does work fantastic on those big nylon zippers like on my pedestal cover. I don't know how old mine is, but at least 10-15 years. The zipper still performs much like new with the occasional McLube treatment. Also for wetsuit zips.
Jun 21, 2007
2,118
Roger:
Your lube track spray solution is uber-creative big time!
