Look's really good, how did you do it?
two passes with 3M rubbing compound using a 6" orbital buffer and then hand apply Starbrite PTFE liquid wax polish, let it dry, and remove with the orbital..
i tried to use 3m finesse but for some reason it made the gelcoat hazy and not mirror like no matter how i applied and then removed..
i won't be able to polish the waterline stripe like this again, i had two tiny spots where if you look closely you can see that the paint is too thin to survive another compounding..
i will say this.. it is an incredible amount of work to return the hull to showroom like this.. i'm going to be really diligent in waxing so i won't have to do this again for a long time..
