On both my previous boat (a 272LE) and my current 322, I pop-riveted a small eye strap to the underside of one of the spreaders and attached a small block. I reaved a line (1/8" ought to do) through the block, and attached a flag clip or small snap shackle at each end. Clip on the burgee, and secure the flag halyard to a shroud cleat. The burgee can be flown as tight as you want it.Thanks, photo shows it perfectly. I have flag hooks on the line already, just can't tighten it like every other line.
You could mount a cheek block on the Starboard side of your mast near the mast head for a flag halyard which you can send up a pig stick with the burgee attached to it, and cleat it off down on the mast.I want to fly my burgee correctly, but the line is not tight so the burgee doesn't fly right. What is the line called that the burgee flys on and how do I make it right? I have a O'day 272.
It's easier to run it up on a spreader than to run up a pig stick to the top of a mast. It's probably going to be a lot quieter on the spreader too. A burgee on a pig stick is noisy, especially at night with a wind blowing.Thank you I like them when they are on the spreaders, and I will try it.
Pete
s/v EmmieLou (O-322)
Little Silver, NJ
Thanks, I'll Check into that! Sounds like just what I need.Indysailor said:Sailcare sells a kit for exactly what Pete is describing- small block with an eye strap and rivets, a shroud cleat and about 40 feet of line (3/16ths I think). Jerry's selling them for far cheaper than the Johnson Marine kit, maybe half the price. It may not be in the catalog, but give them a call.
I'm putting one on my boat this weekend and will take a pic of it.
Used to be true. About 100 years ago."State registered vessels are not allowed to fly the yacht ensign." BS.
The USPS has their own agenda. I *like* my yacht ensign and, since I sail within the US coastal waters, I'm quite happy to fly it from the flagpole aft on the starboard side. I don't know why they feel the need to disparage it.Jackdaw said:
