Recently purchased an '84 25.5, and am slowly resolving issues. Topside she's in pretty good shape, and I've already had her out several times. Most of her problems are below deck. If any of you have dealt with these, I'd love some advice:
There appears to be no electric bilge pump. The wires that run through the bilge are for the mast lighting, I believe. (Electrics are a whole other topic.) Was this model sold with a portable manual bilge pump only? I'm thinking of buying a small one and just keeping a short hose on board for outflow. It appears I could also run to the sink in v-berth, as it flows to a through-hull just below.
There is a white hose leading into the bilge. Is this for a pump located elsewhere? Or is this a drain from somewhere else?
Where does the cool box in galley drain to? My cool box is terribly molded/mildewed and at some point I want to address that.
All of the bilge questions are being driven by a near serious water issue I had a few days ago. PO told me he had never used fresh water tank. Hoses were disconnected at sinks, so I assumed someone had winterized at some point. I hooked them up and started filling the tank, only to discover that someone had removed the T fitting to the two water lines at the bottom of the tank. All 20 gallons or so went straight to the bilge! (Actually I hope that's where it all went. Concerned that some may have gone other routes.) After spending a couple of hours pumping out the bilge by hand, I think I'd like a little help next time. LOL
Thanks for any help,
Ty Thurman
Nashville
PS: Future questions will deal with replacement of cabin wood that has been damaged over the years by slow leaks. I think my bulkheads are still serviceable, but perhaps not. I realize there is considerable stress from chainplates. I'm staying out of heavier wind for now, until boat and my sailing skills are more proven. Sole is bad around bilge access. May eventually replace it entirely. Also, looking to retrofit for shore power.
Ty Thurman
Nashville
