Doh'
....... It is absolutely horrifying that this boat left the factory like this.... Enough said....
The entire tank now needs to come out and be fixed properly or the owner will continue to leak diesel... !!!:cussing:
This is how the fuel gauge sender was installed from the factory. Oh and they cut an edge off the sender to make it fit better...? You not going to seal a tank sender on a lumpy weld with no surface area....
Can we all sing along to builder blunders.... M...I...C...K...E...Y M....O...U...S...E...
