Great Super-Cheap Windlass upgrade
485
Hunter 44 Mystic, Ct
Need Instructions
Art or Steve
Got my remote control this afternoon but no instructions. I can guess what the red and black wires are for but where do I wire it into the contactor?
Art I assume your H 49 and My H 44 are similar. Would appreciate any info.
Thanks
Marc
Apr 6, 2007
120
Hunter Legend 37.5 Isla Saboga, Panama
Art or Steve
Thanks
Marc
Mine arrived today as well. Also w/o instructions. But assuming red and black are + and -, then the other wires will go to the contactor up and down terminals - the same ones the current buttons are wired to. All you can do is get it backwards. If so, just reverse the wires.
Jun 1, 2009
1,860
Hunter 49 toronto
Haven't got mine yet
Guess Canada mail takes longer.
Yes, red & black go to + & - power.
The other 2 wires are the control on the windlass relay.
The wiring is very simple:
On your existing foot switches, they are wired to the 12 V+. The output from each switch feeds the control terminals on the relay.
All you need to do is connect the other 2 wires to the same place the foot switches hook up to on the relay.
If it goes in the wrong direction, reverse the wires.
If you need any other info, email me
A.boas@rogers.com
Nov 18, 2010
25
Hunter 2000 420 Passage CC Summit North Marina Bear
Brilliant idea, thanks Art.
Shame they have gone up up up in price though. Still gonna get one!
Jun 1, 2009
1,860
Hunter 49 toronto
Just got mine.
What a deal!!!
This is very nicely packaged, fits in the palm perfectly.
Powered it up. Range is > 50 ft.
The white wire is "in"
Yellow wire is "out"
There are other similar remotes for the same $10 price range.
It was bizarre that this guy raised his price from $10 to $60 following my post.
I should have said instead of "great deal"... "a good deal at $10, but I woukdn't pay more than $11 for it".
In any case, this isn't what I would call IP66 waterproof. It is "be somewhat careful and don't drop it in the drink" weather resistant. But for the price of 2 beers, it ain't bad. (Canadian beer by the way)
Apr 6, 2007
120
Just wired mine up
just got back from wiring mine up. Works great! The only comments I've got are (1) it makes it even more necessary than before that you turn off the circuit breaker to the windlass when your're not using it. I can easily see some clueless kid picking up the remote, turning it on, and pressing the 'IN' button when the anchor is already fully up; and (2) it's a lot harder to inch the anchor in with the remote than it is with the foot switch. The foot switch responds instantly, both on and off, while the remote has a slight delay, and runs the windlass for about 1/2 second or so even if all you want is a quick pulse.
All in all, a great expenditure of $10!
Jun 1, 2009
1,860
Hunter 49 toronto
Re: Just wired mine up
Glad it worked out. I agree that turning off the breaker is a good idea if somebody might "play" with this. The slight lag you speak if is common to most any wireless remote. I always use the foot switches for the last few inches of snugging up the anchor for this reason. At that point, it is aleady 99% up an in place, do no issue with doing that.
