Thanksthe marinebeam G4 lamps fit all of those overhead lamps.
Pete
Not completely doubting but if you see my thread on the Chinese LED and that I added a regulator to prevent burn out. Total cost was a little more than $2.00 . A close up photo of the back will indicate which chip is being used.Thanks. I have an excellent recommendation for the reputation of this company (see post #18 above). Without that recommendation, I wouldn't be prepared to take a chance. I even have the data sheet on the PWM chip included.
Pete
PS given the size of the chips, I doubt a pic will convince a doubter![]()
Thanks. I have determined that the Array g4 style LEDs sold by Lowes for $8.98 use linear regulation. I'm now testing one.Update: we really like the 1 watt power consumption and the brightness. So far the whiter color has been acceptable. We had occasion to call Nexxus Lighting (makers of Array) with some questions concerning current regulation and allowable input Voltage range. Their tech support is really poor.A linear constant current addition should not be more expensive,See the following circuit
http://led.linear1.org/a-cheap-current-regulated-luxeon-star-driver-design/
The cost of the circuit is approx. 0.5 USD
For marine use I prefer the linear over the pwm version as the switching can induce EMI.
I think we need to be careful not to generalize about $2 Chinese LEDs any more than you can about $20 American LEDsI am told by our dealer in Denmark, that two yachts have caught fire there using the $2 Chinese LEDs. This led us to buy some unregulated resistive bulbs from a Chinese Ebay dealer, and test them. They basically caught fire at 14.8V in about 3 minutes. Here is what we found.:
http://store.marinebeam.com/videos.html
Caveat Emptor.
