Portable Anchor Alarms
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
I have searched and have found a number of older postings regarding portable anchor alarms. Nothing really update though. I am wondering what others use or recommend as a portable alarm. What I would like to do is have a portable alarm by the bed that would alarm if the boat slips anchor. Any suggestions?
I have a Raymarine system on the boat and of course it has an Anchor Alarm but it is just such a power hog and is not by the bed which means if it goes off I have to go up and take a look at it. I would like something more convenient that I can set a bit closer and take a quick look at from the comfort of the bed.
There are iPhone ("Anchor Alarm") and Android ("My Anchor Watch") apps for doing this but not certain how well they operate below decks. I tried the Android app but the GPS is not terribly accurate (+/- 50') and definitely not something I would want to use.
I have looked at portable GPS's but cannot find one that I feel is adequate. Has anyone used a Garmin 72H GPS or 76CSx?
Any experience with the Boat Hooked.com Anchor Alarm system or the really expensive Deep Blue "Anchor Alert".
Any suggestions.....?? :confused:
Sep 6, 2011
435
I use a Bluetooth gps that sits above on deck. I don't know if it works with android for certain but may be worth a peek. It's a Dual xgps150. Amazon had them not long ago for about $80. I know ActiceCaptain just released the free DragQueen but I haven't tried it out yet. SC
Jun 6, 2006
6,990
tie a string across the companionway. Attach a long line to a dinghy anchor and to a frying pan. Once anchored lower the anchor to the bottom and run the line over the string so the frying pan is lying on the floor in view of the birth. If the boat drags anchor or shifts due to a wind change (and potential drag) the line will pull the frying pan toward the companionway then up and start makin a racket as it bangs on stuff.
You can put slack in the line to account for sailing on your anchor also.
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
76CX
I use a 76cx anchor alarm and the batteries last a long time and my wifes Dri=oid is such a power such would not even think of that and my Ray C-80 must use some power but the 76cx which WM had a super deal for it and the g2 chip,I use it for my backup on my boat and also very handy Kayaking here in Florida.
Nick
If you go the Garmin route, you do not need the CSx, which has an altimeter and compass, just the 76Cx.
I have never used an anchor alarm in 30 years. I prefer to anchor securely, using Maine Sail's method. I must admit I do anchor here in Northern California in protected waters. I also admit I have dragged an anchor, but never went to sleep until I knew it was set. I'm still here, but I'm sure many of you others anchor in less protected spots than I have available to me and in varying wind conditions.
That said, if your anchor was subject to drag, then unless the weather changed drastically (for a recreational boater there's always a change in the weather report), then anchor system sizing and technique ought to take a lot of the guesswork out of it.
gpdno
May 16, 2011
144
Watkins 27 Venice
Ed H said:
I saw that too...Anyone use it yet?
Yes, I have used ActiveCaptains anchor alarm. Works well on my iPhone. Just need to keep the phone plugged into the charger otherwise the phone battery will die, then no alarm.
Ed H
Sep 15, 2010
244
Hunter 33_77-83 Regent Point Marina, Virginia
Thanks...I will give it a try... you can't beat the price.
Nodak7
Sep 28, 2008
1,256
Ed, I looked at it and you have to be careful with the accuracy of the GPS on the cell phone. I found mine was pretty far off and not even close to where I would trust it while I was sleeping.
Ed H
Sep 15, 2010
244
I understand that.... It would be better than what I have now (nothing)... But what about this- I don't really care about where "x" is, I just want to know when I am 100 feet away from "x".
Nodak7
Sep 28, 2008
1,256
Ed, if "x" moves, because the GPS is not accurate, then how do you know when you are 100' away because you are are 100' away from "x(2)" not "x". :eek:
Aug 23, 2009
361
Hunter 30 Middle River MD
I actually have found the iphone's GPS to be quite accurate, but that is true above deck. Have had some trouble holding lock below.
Nodak7
Sep 28, 2008
1,256
I have a Droid and found it not to be accurate at all (above or below decks). However my Admiral just got an iPhone and I put Drag Queen on it to check it out. Below decks is where I want to us it so that is most important. I think I have about settled on a Garmin 62s. Seems to have all I need...Anchor Drag alarm, external antenna (for below decks), SD card capable (for maps) and downloadable waypoints (from my chartplotter). I plan on using it for a back-up as well to my Raymarine system. At night it will be the primary anchor watch with the Drag Queen (if it looks good) as the backup.
Nov 8, 2010
11,386
There is a difference between absolute and relative accuracy in GPS technology. Absolute accuracy is how far the device thinks you are from where you actually are. This is the typical GPS error people think of and is important for map overlay of but matters less for anchor alarms. Relative accuracy means repeatable reads of a fixed position over time. This is more what is needed in anchor alarms, and the good news is that lower cost GPS chips that might suffer with TTFF and/or absolute accuracy do better here. And there is things SW developers can do in software (like dwell) that help things.
All that might make you sleep better. But if you did not I'd understand! ;^)
Nodak7
Sep 28, 2008
1,256
Jackdaw, thanks for the information! I think what you are saying is the cheaper GPS's are sufficient for anchor drag alarms. Correct?
Is there any way to tell from looking at them? Is this data mentioned in the specifications for the GPS?
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
I use my handheld GPS over night when I have concerns with the anchor. Usually just let it run as I come into the anchorage then let it run for a couple of hours to see how the boat swings and if it holding well. If we are having a "bad night" I turn it back on and check it if I have any concerns without even lifting my head off the pillow. The picture below was a night on the north end of Lake Worth with unexpected 40kt south wind. We had a bimini and boom tent so a lot of windage on a small boat. As you can see anchor held, 12 ft of water, 50 ft chain and a 22 lb Delta anchor. It was our 2nd day there so anchor was well set. We were in a slip the next night ;). This GPS model has an anchor alarm but I prefer to just look at the screen to see what is going on, our boat does a lot of sailing on the hook and will set off any anchor alarm.
Bob
11,386
I'm saying that even if your phone's GPS is very slow to get a fix, or seems erratic when running a car nav program, the relative accuracy of its GPS might be just fine for use with an anchor alarm.
I'd suggest experimentation and good prudent seamanship. Try an app that records tracks and place you phone in a secure place in your boat, connected to power. Ideally no one will be able to pass over it, either below or on the deck, blocking or changing GPS reception. Look at the track to see if it looks 'OK.
I talked to Jeff before he released Dragqueen and he has done some smart things in the app. The app reports accuracy (really EPE, or estimated positional error), and includes delay before an alarm sounds. This is a good idea because it prevents the app from tripping off of one or two 'outlyers', or bad reads. He's done a good job.
Nov 8, 2007
1,620
Garmin 76cx
Our handheld gps works fine when we need it, even inside the cabin.
But most of the time, with an anchor matched to the bottom and well set with a scope of 7, we don't bother with an alarm, and sleep just fine.
