6 Year Wal*Mart Battery Observations
11,722
UPDATED 11/13/12: Changed the title from 5 Year to Year and added to the thread.
Behind the scenes I have been conducting my own little experiment on "inexpensive" batteries. Five years ago in June I purchased three new "deep cycle / trolling" batteries from Wal*Mart all the batteries were from the same date lot (F7) or June 2007.
They were installed in early June of 2007 and run for our normal seasons as follows:
6-2007 - 11-2007 + all winter on-board in Maine
5-2008 - 11-2008 + all winter on-board in Maine
4-2009 - 11-2009 + all winter on-board in Maine
5-2010 - 10 -2010 + all winter on-board in Maine
4-2011 - 11-2011 + all winter on-board in Maine
4-2012 - 11-2012 +.......
Total engine hours during the last six seasons has been 823.2 (we have engine driven refrigeration which probably added 200 or so hours of use)
The parameter for my observational study were simple. Try to treat the batteries as an average boater may do with the exception of a solar panel.
What does that mean?
On the "bad for the battery" side it meant:
*No equalization, ever, for the full six years (they have still never been equalized). Please note that I am a FIRM believer in periodic equalization charges for WET lead acid batteries!! This however is not what "the average boater" does so I specifically excluded it from my experiment.
*Batteries were "topped up" and left on-board, but 100% disconnected, during the winter and NOT left on a charger. They were topped up perhaps every four to five weeks at best, except for the winter of 2010. During the winter of 2010 they were left without charge for 5 months straight because I wanted to see what self discharge and the resting voltage would be come spring. (note that I placed this under "bad for the battery" because that is what most boaters believe, I do not believe this)
*Used only a simple Guest 6A battery charger for any "off season charging" (mostly for "on the hard" charging of the DC system when working on the boat and using DC loads like lights or stereo)
*Used a "DUMB REGULATED" alternator (14.4V set point and no float) for all charging other than solar. 823.2 hours of "dumb charging" over six seasons....
On the "good for the battery" side it meant:
*Normal watering and checking of electrolyte levels
*Never discharging the bank below 50% state of charge (though I did on a few occasions dip to 30% SOC). Average depth of discharge was 30% or drawn to 70% state of charge. We did this through conservation efforts such as LED lighting and 12V appliances vs. 110V.
*Always charging the batteries back to 100% after each use via solar (we are on a mooring)
*Keeping the terminals clean
*Used sufficiently sized wiring to prevent voltage drop in the alternator and solar charging system
* Monitored performance each year via specific gravity, load tests, capacitance, pulsed load testing as well as Ah capacity testing (last three seasons for Ah capacity).
So how have they done?
They have done VERY, VERY well and still test at better than new on CCA ratings as tested with the ARGUS AA500PWP pulsed load analyzer, a Midtronics EXP-1000HD capacitance tester. The Argus is a $750.00 tool and the Midtronics is nearly $2000.00. Suffice it to say the Midtronics is the industry "gold standard" for battery analyzers. I also use a good old fashioned carbon pile load test (500A carbon pile tester) at 50% of CCA (340A) for 15 seconds.
I also constructed an Ah capacity tester using a Victron BMV-602 battery monitor and a fixed load matched to the 20 hour Ah rating of the battery. This works fairly well and shows the batteries still at over 94% of capacity from new. I would need a fixed digital load control to get more accuracy but they cost thousands of dollars so some 12V bulbs act as my "load". While not 100% accurate it is about as accurate as you're going to get without spending thousands of dollars to test the 20 hour Ah capacity.
Ah Capacity Test:
The Victron BMV monitor has a programmable normally open relay built into it that will make & shut the test off at 10.5 volts, which is how a 20 hour Ah capacity test is done. Rigging this up required an additional "ice cube" double pole single throw relay and a 9V battery to power the coil. It was pretty easy to build and assemble if you're handy.
A 20 hour Ah capacity is figured like this:
100Ah battery, divide by 20 = 5A
or
125 Ah battery, divide by 20 = 6.25A
or
70 Ah battery, divide by 20 = 3.5A
Based on the above calculation you would apply a 5A load to a fully charged 100Ah battery at 77F until it dropped to 10.5V. This is how I run my capacity tests. When the battery hits 10.5V the Victron relay makes and cuts the test off at 10.5V. I had to program the battery monitor to do this at 10.5V and also set the "break" voltage at 12V as it would not climb back up there and re-connect the "load". So battery hits 10.5V, relay makes and disconnects the load via the double pole double throw relay. The Victron relay keeps the load disconnected until the battery voltage climbs back to 12V. Once the load (light bulbs) were disconnected at 10.5V I then read the Ah screen to figure out how many Ah's the battery delivered over the test. Pretty simple though not "pin point" accurate.
It should be noted that a capacity test completely kills the battery and the battery must be charged back to 100% immediately after. This is NOT something you want to do on a regular basis. I do it because I am curious to see the differences between capacitance, CCA and load tests when compared to a "capacity" test. Who knew there were soo many methods for testing batteries??:doh:
As of two weeks ago this is what the three June of 2007 125Ah batteries delivered:
Battery #1 = 117.7Ah
Battery #2 = 118.3 Ah
Battery #3 = 117.9 Ah
All these batteries are at roughly 94% of their new rated 20 hour capacity. New batteries often perform above "spec" so they may be lower than "new" but I had not built this particular capacity tester 5 years ago so I was unable to draw an accurate baseline. My guess is that after being broken in I might have seen 130-133 Ah when new. Of course I can't really say and it likely could have been 125Ah just what they are rated for.... ??
The only slight problem is that it is very difficult to hold the amperage at exactly 6.25A so there is some load variation, which could in-theory, throw the Peukert factor off the 20 hour rate ever so slightly. The bottom line is that with a 6.25A load, cut off at 10.5V at 77F, this is a pain because you need a really warm room in your house for a few days, the batteries are still in exemplary shape for what I paid.
This entire bank cost me $209.64 or $69.88 each! If you're doing the math in your head that works out to a cost of 55¢ per Ah. Broken down by year the entire bank has cost just $34.94 a year when amortized over the six years of ownership. If they last seven years that will make them $29.94 per year. Of course I am in Maine so there was a 5% tax too.:cussing:
After doing some very extensive research I discovered that these batteries were actually built by US Battery then sold to Johnson Controls and then sold to Wal*Mart and labeled as a group 29 case size. There's ideally no such thing as a "group 29" battery so it's really a group 31 US Battery, 12v battery. Group 29 is a Wal*Mart / Sam's created designation which has gained acceptance as an industry designation.
The batteries are rated at 125 Ah for the 20 hour rate and are as heavy as any comparable group 31 deep cycle battery (within 1 pound of the Deka's sold by West Marine). US Battery actually builds some excellent quality batteries.
So what do I attribute this "good" performance of what most would call "junk" batteries?
#1 Topping the batteries back up to 100% after each use via solar - Numero uno most important aspect of battery life! Over the years I have found that batteries tend to like the partial/day charging regime, and low current charging, that solar can provide. This slow charge via low current can penetrate deep into the thicker battery plates and provide a true & full "deep charge". Even if we ever decide to keep our boat at a dock they will get charged only via solar and the boat will remain isolated from the dock unless I choose to install an isolation transformer to run some AC loads like our dockside fridge. I simply will not charge them at a dock with a "shore charger". (Not suggesting you do the same this is my personal preference for our home waters, which are cool, and see our battery compartment at under 70F all year). If I did not have solar I would charge "periodically" as opposed to constant, but again my personal preference...
#2 Not leaving them on a "constant" float charge as if I was tied to a dock - I see far to many glitches and failures of shore chargers to bother doing this if I already have solar, which is very stable and reliable. While there are exceptions to every rule I tend to see batteries that are constantly "plugged in" not make it much beyond the 4-5 year mark when using industry analyzers and the 80% rule for CA "capacity".
Despite exceptions to the rule, the "rule" is often not defined, or varies from one boat owner to another. I have one customer who's rule is "If I can't make a call on my VHF I need new batteries" he gets 7 years out of his bank that would have failed any sort of capacity testing at year three of four. He has a pull start out board and a small ferroresonant shore charger so starting heavy loads is not in his particular capacity "rule".
#3 Keeping them topped up with water - This is one of those areas some folks just choose to ignore. It is easy, unless access constrained, and usually takes less than five minutes and under $1.00 of distilled water. I also check the specific gravity with a sight refractometer yearly. Testing for SG can be a PITA but it can tell you when a battery cell or cells is starting to to get out of balance and go bad. It could then be removed or equalized bad returned to service and not cause harm the remaining batteries.
#4 Storing them in a COLD climate - Cold drastically reduces the effects of sulfation and the chemical process slows way down. During the winter of 2010, during this "personal observation", I actually let the batteries sit from November 2 to April 10, on-board in cold Maine, with NO occasional charge as I usually did every four-five weeks or so. In early April the bank still measured 12.61V.. Full on these batteries is 12.73V -12.74V (resting OCV). If it had been 80F this bank would have been dead and likely ruined. Thanks to the cold winter temps here in Maine their life was prolonged, not shortened, despite not being charged for five straight months.
I DO NOT recommend this however! I am sure I had some stratification going on, where the acid sinks to the bottom of the case and the water migrates to the top, which can be bad for the batteries, but these "cheap" batteries, "junky" as some might say, survived the winter of 2010 and are still performing WAY better than I thought they would.
#5 Shallow cycling
- Our average depth of discharge is about 30% of capacity but we still do have times where we let it go to 50% or 70% depth of discharge. The vast majority of cycles however never went much below 70% state of charge. Shallow discharges lead to longer bank life and more "cycles". When I ran our calculations we only needed two batteries but I added a third to keep the depth of discharge as shallow as possible.
I do believe cold storage and solar greatly aid the longevity of a battery bank and that "dumb regulators" really don't harm them any, after all how many cars, trucks and buses are there running 14.4V all day long. Also as "sailors" you would need to run the engine for a long time to get to a properly programmed "float charge" voltage. Most sailors don't want to run the engine that much so most smart regulators are in bulk or absorption voltage the majority of the time. If there is one thing you can do to keep them lasting it is not to draw them too deeply and to always charge them to full as often as possible to keep sulfation at bay. Shallow discharges can really help your batteries over the long haul.
These are the three batteries as tested in 2011 for CCA performance. The batteries are slightly off each other at; 801 CCA, 813 CCA and 790 CCA and some if this is simply due to the % accuracy of the meter when you get into an area like a 10 CCA differences. Some is likely due to the fact that these batteries have never been equalized. It should be noted that the factory CCA rating of these batteries is 675 Cold Cranking Amps. They have always performed well above that.
This was a capacitance test performed between one of my batteries and a brand new "off the shelf" battery at Wal*Mart done in 2010. It's hard to tell the difference. This test was set for MCA or Marine Cranking Amps which is based on 32F... They have always performed well above the MCA rating too as many batteries do.
Disclaimer: This is NOT a recommendation to run out and buy cheap Wal*Mart batteries, in fact I would NOT buy the current version of our battery which is NOT THE SAME. This is just an observational report, an (n.3), in the whole scheme of things measuring all aspects of the batteries over their life..
In fact, at this point in time, I would actually advise against buying the current Wal*Mart deep cycle marine batteries as the rating on them is ridiculously incorrect. They are not the same battery I got six years ago and they changed last summer. I don't suspect the new Marine Maax 29 is the quality of the one made by US Battery for Wal*Mart.
The new deep cycle batteries at Wal*Mart are rated at 125Ah with a 1A draw.:confused: This is nonsense in terms of an "accepted" Ah capacity rating. By industry Ah capacity testing standards for deep cycle batteries a 125Ah battery should support a 6.25A load for 20 hours before dropping to 10.5V.
I suspect the marketing department, in charge of stickers, really messed this one up. On further investigation I found that it's impossible to get any information from the Wal*Mart or Johnson Controls on these new style Wal*Mart deep cycle batteries.:doh: In short "nobody knows nothin";)..... Heck it took me two weeks to figure out US Battery had actually manufactured our batteries and they were the only ones who knew the Peukert Exponent number for them. JCI & Wal*Mart had no clue..
If going "off shore" or doing extended cruising I would chose a more premium battery and add a bigger alternator with external voltage regulator. For the 7+/- months of cruising we do, in Northern New England, and we do use the boat a LOT, I sail it at least 5-6 days per week this type of set up can work and is a very inexpensive way to get 12V power on-board.
If you want a reasonably priced good quality battery Wal*Mart's sister company, Sam's Club, has taken on the Deka/East Penn line in many areas. They are sold under the Duracell brand. I have called East Penn and confirmed the only difference between these batteries and the SAME batteries sold at West Marine, for more than double the price, is the "sticker".
See this post for more info: Battery Buyers = Good News (LINK)
EDIT 11/13/2012
Our boat is still in the water but the other day while there I took some "end of season" measurements, on our bank of batteries. They are just completing their 6th season.
This is the bank of three Wal*Mart group 31 batteries purchased/installed in the spring of 2007.
Unfortunately all I had with me was my Midtronics analyzer and not the Argus analyzer which is what I have been using as my baseline. Still, it was a cold morning and the batteries themselves were at 32F. I wanted to see how they tested under these conditions for capacitance as well as voltage dip during starting...
This first photo shows the resting voltage , though not technically "resting" as they were still connected to the system. The batteries had been disconnected from the solar panel for about two weeks. Our system has a 0.1A +/- parasitic load and the open circuit voltage at the end of two weeks was still at 12.69V.. Normal full charge resting voltages for these batteries has been 12.72 - 12.73V
The analyzer also shows the measured cold cranking capacity or "CCA". Each of the three batteries is rated at 675 CCA so all three in parallel should be at 2025CCA. At 32F they put up 2071 CCA which is still 46CCA better than their "as new" rating.
The display also shows the actual battery case temperature. I had left my battery box open so they were not kept as warm as normal, by the bilge temps..
I did not have the time to break them apart and test them individually. That is the best test. I will do a lot more testing including a 20 hour Ah capacity load test when the boat gets home.
Season six went from April 16th 2012 to (still in the water)
Battery Performance:
This next shot shows how the battery bank and system wiring performed under starting conditions. These numbers are the "averages" during starting.
The first line is the average voltage during starting. Anything over 10.5 volts is considered good. The bank has a slight dip to the high 11's but recovered enough to still maintain an average voltage during starting of 12.04V at 32F...
The second line is the average amps during the starting duration. With the engine cold she draws more in-rush and overall current during starting than when she is 70F like during the summer sailing season. The peak in-rush current was about 640A and the average was 286A.
The third line shows the time it took for our motor to start from the first click of the starter until the starter became "unloaded".. The entire duration of time it takes for our 44HP Westerbeke engine to fire is just 746mS / 0.746 seconds or roughly 3/4 of a second to fire....
The last line is the average starting circuit resistance. It shows 15.1mΩ/milliohm or 0.0151Ω / Ohms of resistance in the circuit. This is an excellent number meaning our cables and connections are in very, very good shape and properly sized.
The next photo shows what the starting current looks like graphed out remember this represents 0.75 seconds of time:
The last photo shows how the battery bank supported voltage during the starting event. This is exceptional performance for six year old deep cycle batteries that have been in a deep cycling application. What makes this even more impressive is what temperature the batteries were, 32F....
For a $210.00 bank of Wal*Mart batteries, that have never been equalized, and have been stored on the boat every "harsh winter" winter, and even went one entire winter without being "topped off" at all, I'd say were are getting stellar performance.....
The only changes made to the system this year were upgrading to a 140A alternator & serpentine belt kit, but they are still charged via a "dumb regulator" not a "smart" one. I also changed the solar panel from an 80W to a 140W panel. The Genasun MPPT solar controller is still the same.
More testing to come over the winter.....
Oct 2, 2006
1,517
Jboat J24 commack
Re: 5 Year Wal*Mart Battery Observations
Thank you again for very usefull info
dqb24
Nov 4, 2011
49
Quintessence Hunter 34 Annapolis, MD
Great write-up. Thanks for all your research.
What size (wattage), brand solar panel do you have or recommend for top-off/maintenance ?
11,722
It's an older 80 Watt Siemens (now Solar World) monocrystalline panel run through a Genasun GV-10 MPPT controller. If you focus on a panel with a written or stated marine warranty you'll do fine..
Aug 20, 2010
1,399
Oday 27 Oak Orchard
Thanks Maine Sail. I will be replacing my batteries soon and will opt for the cheapies. I figured a couple hundred a season for batteries in the maintenance schedule. Nice to know I might lessen that cost.
11,722
The Sam's Club Duracell's are an excellent value and are actually Deka / East Penn batteries which are a very good marine battery.. Wal*Mart has changed their marine batts so no guarantees there....
544
Bristol 43.3 Perth Amboy
Very interesting
Great info!
How do you suggest sizing the solar charger to the bank?
Nov 6, 2006
10,150
Really good info, Maine.. Thanks ..
I have been using the Wal Marts for a while .. My maint schedule was terrible and never had a set last more than 3 years. After Hurricane Katrina, I replaced the old ferro-resonant with a Xantrex smart charger (shuts down when batt is full) I installed a remote watering system because battery access on the 34 is terrible. The batteries are always full since I am in a slip. Batteries are now 5 years old and still useful.. It is not cold here most of the time! I suspect I will change them after next summer.
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
For maintenance / top off of a day sailor or occasional weekend cruiser you want a panel that outputs in watts 10% of the bank's ah rating or more (so for a 100ah bank, a 10w panel or larger). With a good charger like a Genasun you should find the batteries are always topped off whenever you get to the boat.
If you are going to be relying on solar for primary charging while doing extended cruising (defined by me for purpose of this conversation as any trip that with normal engine use will deplete the battery bank below 50% before returning to the dock), or living aboard, you will probably need more than that.
11,722
Ideally you want the alternator to bring the bank back to 80-85% state of charge and then let the solar panel do the rest, when you're not there during the week. If you want to satisfy cruising needs such as refrigeration, instruments, AP etc. then your array will get quite large.
The faster you can bring the bank from 80% to 100% the less sulfation you will have and the longer battery life you'll get.
For a sizing example, lets look at a bank of 300 Ah's for "mooring recharge".
With simple math you can see that the last 20% of capacity is 60 Ah's. However you need to take charge inefficiencies into account too so you'll really need to put back in about 70Ah's +/- to get back to 100% state of charge.
For sailboats on moorings the panels are usually left flat when your not there so that you can capture "most" of the sun. In a land based installation the panels are fixed, the property is not moving like a boat does, and can be angled at the sun. This is not so on a boat, so panel position is very often a compromise. If you are at a dock you can rig the panels and aim them more appropriately but not on a mooring or off cruising where your boat will swing at will.
Because of this you can figure on about 4 - 4.5 hours of full output per day on average, for the Northern climates, and 5-6 hours per day the closer to the equator you get.
Some folks use 5 hours per day in the Northeast I found that to be a little to generous.. Some days it will be more some less but here in Maine 4 - 4.5 hours at full output works best.
So, a 300 Ah bank @ 20% down = 60 Ah's that need to be returned + charge inefficiency = 70 Ah's total needed for "full"
A 2.5A output panel, roughly 45 watts, X 4.5 hours = 12.5 Ah's/Day returned to the bank. If you have phantom loads, like a propane sniffer or other "always on" loads, subtract those and that is your "net".
Next divide 70 Ah's by 12.5 and you can see that it will take approximately 5.6 days to go from 80% SOC to full on a 300 Ah bank with a 45 watt panel..
That's a little long so a panel in the 3.5A output range or more would be better served. A 3.5A panel shaves a full day off the time it takes to hit full in that scenario.
You want to size it to get back to full as quickly as you can. We use an 80W panel on a 375Ah bank. We need to put back about 85Ah's (from an 80% state of charge) and our panel can do about 4.6A (I'm not including an MPPT boost here). So it takes us about 3.5 - 4 days to get back to full depending upon where the alt left off. In my opinion this is a little long and I'll eventually upgrade to a 135-150W panel which will drop us to roughly 2 days to full from 80% SOC...
Mar 8, 2009
530
Catalina 22 Kemah,Texas
No more prorated warranty on Walmart batteries, I just put 2 in my pickup. Group 27 has 3 year free replacement and then no warranty. They cost Me $100 each including tax and state battery cleanup fee.
Jul 24, 2006
628
Legnos, Starwind, Regal Mystic 30 cutter, 22 trailer sailor, bow rider NEW PORT RICHEY, FL
whew,math made easy
thanks Maine for the math for dummies. Gets alittle complicated in mthe books with so many variables. You make it simple and easy to understand. Any chance that you'll be publishing a book soon? I have N.Calder's stuff and would add Mainsails's stuff to the library. Given your simple instruction i can easily figure off the grid requirements for full time livaboard. Pat
Jun 6, 2006
6,990
I built a spreadsheet that accounts for all the stuff Mainsail noted. Battery charge and discharge efficiency, solar output variance through the day, SOC affecting the amount of amps you can input etc.
I built it to help me understand how the use of electricity on board and the production of same effects the battery SOC and to help me size the various components (wind, hydro, alternator, LED lights, etc) on the boat.
I found that in general you want to avoid storing electricity if you can. Use it as you produce it and avoid the charge/discharge/self discharge inefficiencies (~20% in a lot of cases). So it is cheaper to buy a timer/photocell to turn on your reefer at dawn and off at dusk than to buy a bigger solar array and run the unit all the time. Which would support the holding plate type of reefer system being preferred……
Hydro is the best for loads while on a long passage, a combination of solar and wind is best for at anchor, there is no replacement for more storage, the difference between smart alternator regulators and dumb ones is only noticeable when you deeply discharge the batts on a regular basis (which you should not do so dumb is ok and take that money and buy more storage),
Unfortunately this is not ready for prime time and takes an “engineering eye” to get the most out of it. I’m looking for input on improving it with the intent of posting it on the site for anybody to use (and me of course) so if anybody want to be a test dummy let me know and I’ ll email you a copy.
Dec 8, 2007
303
-mac 26M -26M tucson-san carlos mx
other johnson control batteries that are sold under another store name are Interstate Batteries,Optima,autozone gold, just to name a few.It's humorous to see someone bragging about the performance of their Interstates and berateing walmarts batteries when they are one and the same,only different stickers applied at the end of the assembly line.
Oct 10, 2008
38
Ericson 34 Lk Champlain
When you spend millions on batteries you get the plates you specify. Don't assume that the manufacturer only has one design. A little less lead and a little more spacer saves a lot of money.
Also, if the customer wants to quote a few more amp hours it is easy enough to make the acid a little hotter. Hotter acid reduces life.
Oct 8, 2008
362
MacGregor/Venture 25 Winthrop Harbor, IL Drummond Island,MI
Maine.....you ARE the battery MAN! Love your posts. I'm not sure who made the Sam's Club batteries I bought in 2003 for my off grid cabin, but I hope whatever I replace them with last as long. I note the voltage drop while the well pump is running (110 amps) and get a fair wag at capacity. To be fair, these batts do not get cycled very often, they are loved;-) Except for one winter when I didn't adjust the solar panel angle and snow covered them up, voltage dropped so low, the solar regulator never came back online when the snow melted.
385
Harpoon 5.2 Honolulu, HI
Thanks for the informative article. I've been using Walmart deep cycles for years in various boats. Most of my use is just weekending / daysailing with no refrigeration demands. I can think of only one that has completely gone flat, but that one also sat for a long time when I was deployed.
Dec 8, 2007
303
t metzger, scales don't lie, mainsail weighed the batteries and compared the walmarts versus dekkas with a one pound difference last time i bought lead it was 1.40 a pound. i don't think that justifies a 100 percent difference in price, i think it boils down to people buying a specialty niche due to shrewd marketing and bragging rights.they don't really understand what their purchasing or how it works so figure if it costs more it must be better which doesnt hold true in todays world internet market.
11,722
Actually if you compare Deka /East Penn at West Marine to Deka / East Penn at Sam's Club they weight exactly the same because they are 100% the same battery, except for the sticker. The WM/Sea Volt sticker, must be gold leaf, will set you back MORE THAN DOUBLE in many case sizes...
Paying double the price for no difference, is a lot worse than comparing a Trojan to a Johnson Controls battery where there are "some" differences..
