+1 to what Bill said. I have a 29.5 and don't see how you could install a windless. The anchor well is very shallow and I figured I would be untangling piles of chain that would stack up. Also I didn't want to cut up he anchor locker hatch. If breaking out the anchor is a problem I would tie a float with a trip line.I'd ditto what everybody else said and add "how are you going to power it?" 750 watts is about 1 horse power or 750/12=62.5 amps draw at max load. While the energy draw is not that much due to a) then engine is already started and the alternator will try and keep the batts up when it sees 11 volts and b) you don't run the windlass for very long so the amp hours are small (three minutes of max load would be 62.5*(3/60)=3.1 AH.) But you still have to have cables to the batts that can handle the amps and not get hot. This brings up a host of questions;
How long is the circuit (sum of out and back)?
How big a cable do I need to support that length and the amps needed?
Can I route that big a cable through the intervening spaces?
Where do I put the electrical controls?
Do I have sufficient drop from the caspsin to the anchor locker to even make the thing work without constantly knocking down chain castles?
How do I handle chain AND rope rode? (this one may not be an issue)
Can I get a direct line between the caspsin and the bow spirit so the chain does not slip off the caspsin?
Would a hand crank windlass (and only anchoring in snug harbors where the wind and waves are a lot less) be a better solution given the amount of cosmetic surgery and standing on my head in a phone booth pulling cable I’m going to have to do?
Lloyd, ya have to understand how the forum works. If, say, you want more information for whatever need, you post your plea. Then you will probably get these three responses (in no particular order) "Why do you want to do that", or "You shouldn't do that", or "Here's what I did", none addressing your original plea for knowledge. Then Stu will refer you to a Catalina link and close by saying "It's your boat, your choice". After some other replies, Maine Sail will come along like the guy with a shovel behind the elephants and clean up all the C*** that's been disbursed along the way. You may or may not get the needed answer, may or may not get a factual answer- but you'll still have to figure out which is which.I thought the question was how to do it, not, do you think I should.
Don't overlook the French Beneteaus- that's 'clieu'...... to mean "Help me understand what I'm getting into cause I have not a clew (or possably even a tack)"
