Fuel Pump Mystery
11,723
The Carter rotary vane pump below has about 1400 hours of polishing on it. It can move 70+ GPH through our Racor 900 and other than being a little noisy, and drawing more current than the Walbro, it has proven to be very reliable and also inexpensive, got it at NAPA. These were originally designed for the US Military. We have started our motor hundreds of times, with it running, and suffered no issues. Of course I have not been able to measure any spikes on our system even with an o-scope, so this should not be an issue.
I know the Walbro pumps are very often used in these applications, many of the mega yachts use them, so perhaps Roger just bought the wrong one for his application. I know Rich H. also uses a Walbro. A call to the manufacturers tech department may be a good move as they could advise on possible reasons for failure and the best pump to use for the application..
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
I bought the one Rich recommended when he helped me work out the system. If they are used for injector cooling, basically recirculating fuel at low head pressure, they have got to fit my service profile.
7000 miles of cruising is probably 1000 hours of operation the way I travel. That would qualify as an early failure but the unreliability of just about everything made these days makes me willing to risk that it was an early production run aberration. I'm going to give Walbro another chance but will buy a second one as a spare in a few weeks if the one waiting in FedEx at the marina this morning doesn't die a quick death.
Later:
FedEx came. The instructions for the new pump include the phrase, "for fuel polishing applications."
3,562
Facet Pumps seem to be a hit and miss proposition.
Fellow on the next boat saw me working on my engine and we got to talking. He just lost his fuel pump, the regular fuel supply lift pump, and bought the same Facet pump I did at NAPA to keep him going until he could get a heavy duty unit.
His pump worked for 20 minutes so he thinks I did well to get a day for my 60 bucks. His was working as intended, design wise. These pumps are junk.
11,723
You have to be careful which Facet pump you buy. I've never used the plastic one sold out front at NAPA. We have the Facet cube style pump, Pro-42 model, and she's got 3300+ engine hours on her. I have a spare one that is collecting dust.. The older cylindrical style Facets also lasts a good long time. Most every Universal or Westerbeke out there has a Facet pump on them and while they can fail they are quite reliable. Was working on a mid eighties Ericson today that still has the original Facet pump...
Mar 6, 2008
1,417
Being in electronics I have seen how a spike can kill electronics circuits. Assuming this is what kills the electronics of the pump - the solution is very inexpensive. Simply add a 1 AMP diode just where the +VE and the -VE leads of the pump is at. The diode must be connected in parallel to the pump leads. The cathode goes to the +Ve side and the Anode goes to the -VE side. When the circuit is turned off the spike will forward bias the diode and the reverse voltage will not exceed 0.5V. For those who are not familliar with a diode and its designation - It looks like a large resistor and has line on one side. The line is the cathode side.
Jun 6, 2006
6,990
the pump in question is just a coil of wire and a machanical switch. I seriously doubt that a spike could kill it. It would have to be a pretty high amp spike IMHO.
Dec 2, 2003
1,637
Joe,
Your solution only works for spikes caused by switching off the pump's own coil or any other negative spikes. i.e. to handle positive ones as well one needs the varistor.
Mar 6, 2008
1,417
Donalex - there are no spikes created when first turned on. Like you said it is only when turned off. The collapsing magnet field creates a very high voltage across the points where it is cutting off the current. Diodes are very commonly used across relay coils to kill the spikes.
Nov 22, 2008
3,562
This pump is essentially a large coil being turned on and off. I would imagine that spike damping was incorporated in the design.
Jun 6, 2006
6,990
I think that you will find that the spikes in question to be on the order of 50 volts max for this device. A simple capacitor across the power and ground fixes this. As Roger suggested this has probably been incorporated into the design already.
The spikes are not what is causing this pump to fail. It is how it is being used. They are designed for continuous operation as a fuel supply pump not a fuel polishing pump. completely different application
Nov 22, 2008
3,562
No, the instructions that came with the pump clearly state that fuel polishing is an intended service.
Waybad
Nov 12, 2011
25
Skookum 34 34 Custom DesMoines
From waybad, My best guess is your alternator took out your pump. If somthing goes wrong even for a split second it can take out any number of electrical Items. electrons move very fast. Coils can show resistance and still not function. Use a fuel transfer vane type pump for moving fuel threw a filter and the walbro for small engine or stove use. Short of using a megar on your winding or coil, their is know of knowing if it is good.
I use a Jabsco spo-60-n for moving fuel. It is fast and efficent. If you needed it as a emrgency engine pump you would need to add a presure switch to run it. good luck, I see lot of advice is available.
Nov 22, 2008
3,562
That would be near the bottom of the list of suspects for me. These pumps are designed for automotive and truck use as well as marine and to be wired exactly as mine (turning on when the ignition harness is energized). If they were vulnerable, Walbro would be getting lots of complaints.
There is a lot of other stuff on my boat far more vulnerable to spikes and nothing else has failed.
I think it's just one of those random early failures of an electronic device. I seem to have a special karma for these things:
http://forums.sbo.sailboatowners.com/showthread.php?t=130886&#post824024
