removing companionway trim
423
S2 9.2A Newport News, VA
I'm attempting to remove the grab handle and the teak trim on the inside of the companionway, starboard side, on my 9.2A. I want to run some wiring for a digital engine temp gauge (http://www.fullwavemarine.com/tempgauge.html) and, eventually, some cable for cockpit speakers. I can't get to one screw under the grab handle. I thought I'd remove the handle, but couldn't find any plugs to knock out. I looked on the outside of the companionway, but didn't see any screw heads that corresponded to the thicker part of the handle. Well, I didn't see any screw heads, period.
Am I missing something, or do I need to try an offset screwdriver on that remaining screw?
Thanks.
John
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Thanks.
John
John....if memory serves right i had the same problem when dismanteling mine...the best i can remember i think i ended up prying it off ...knowing that i was changing mine from single loop grabs to double loop grabs...but for some reason in the back of my mind i am thinking that there is a plug i missed...you may want to sand the surface and see if the plug is there...hope this helps...
regards
woody
Apr 27, 2011
423
Thanks, Woody. You're a help, as always.
I'm going to try the offset screwdriver first, to see if it'll come loose at that point. If not, I'll try sanding a bit to see if a plug shows up.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
i found the pics of the table this morning and you did a good job shooting them thanks for the time and trouble.....if you find the dimentions plz send them to me or post them with pics ...again thanks
regards
woody
Apr 27, 2011
423
regards
woody
If I don't come across the dimensions shortly, I'll take them again. It is one heavy SOB. Don't think I'd want to be around it if the boat turned turtle!
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
ahh yes now i remember ...you are correct ....glad you posted this now i will be able to answer the question ....,,check your message.....
regards
woody
