Charts and VHF radios???
109
O Day Mariner 2+2 my driveway/ Lake Wallenpalpac
First I've a newbie sailor, last May I took the ASA course, went out in July and bought a 16' American Fibergalss A-16 and sailed her just about every puddle close to me.
So, this new world is all alien to me, so, bear with me;)
Being your "A" typical male- sold her and bought a '71 PT 1/4 22', (I fell in love with her hull lines)!
She needs work, (what else is new? EVERYTHING I buy "needs TLC").
Sails being made, hull, deck sanded, new stays and sheets siting in the shop, the cabin (small by standards as I see now) is coming together in my head, all I need is warm weather to put her all back together.
I'll start sailing her in a local large fresh water lake close to me, (if the slip can be secured) and with the BIG truck I just bought to haul her @, travel to????? to try different waters. (My buddy has a cabin at the 1,000 islands and goes there each weekend to fish, so that's one of my "bucket lists places to sail).
She has NO wiring, so I have to start fresh.
A few questions.......................................
With my A-16, I just kept my "druggie phone" (A track phone I kept in my saddle bag of my motorcycle when I travleled) in case Jaws came after me or a Mermaid suduced me and I needed to tell my wife, order a pizza.
In the ASA book they gave a list of stuff I SHOULD carry, the instructor also gave me a list, but figured it was for "real sailboats, not my little "B-cup".
Now I got myself a "real boat"!
The book said to have....
Signal flares (or flag), I had the flag, was on;lt doing day sailing.
Noise maker-I had a whistle and a small hand held air horn
Fire Ext. (even though I had a electric motor, I figured why not)
a "stout" tow line-incase my sails ran out of gas or wouldn't start??????
More than enough PFD for adults 1 kid and me dawg.
C.G. approved seat cushion.
anyhitng else I'm gonna need now?
A what point should I get a VHF radio for my PT?
Is there a difference between a portable VHF and a portable "Marine VHF"?
Should I even look at a portable?
Is there a "standard channel" (like #9 on a C.B.) I should have it set at?
Where is the antenea usually mounted? My mast?
Seems like there is a LOT stuck to the top of it...... the anchor light, wind direction indicator, antenea........ There is only sooo much room up there........................
As for charts......................
I'm a map junkie, always have been.
When my good Uncle sent me to southeast Asia for a vay-k, I was the one who read the maps, (you can't trust a officer for anything, NCO's run the army)!
I can sit and look at top. maps, road maps, all day.
I've been looking @ at marina local for charts to practice my nag skills, (U tube is a great learning tool), but all I have found are your basic map showing the lake in question and not much else.
I wanna practice then take the nag ASA course.
(anyone can use a GPS to nag with, but, I'm old school, one day those satelites are gonna fall from the sky and a lot of sailors are gonna be lost, but not me!!):D
Is there a on line site to get charts of the waters I want to sail on??
So much to learn, so few $$!!!
Welcome and all the best.
www.boatsafe.com
The US Govt has online charts, which can also be printed out in booklet form.
http://ocsdata.ncd.noaa.gov/BookletChart/AtlanticCoastBookletCharts.htm
VHF handheld is just fine for now, and you can take it with you. Yes, Ch. 16.
GPS is up to you given where you say you'll be sailing. I have a friend with his dad's sailboat up in the 1,000 Islands, he carries a HH VHF and his hh GPS. Garmin's GPSMap76Cx is on sale for a ridiculously low price at West Marine. I've had mine for over 5 years and still don't need or want another.
Take it step by step.
Jun 6, 2006
6,990
First off, when are you getting your next (and bigger) boat? ;-)
You have all the basics covered. Course those NOAA charts are going to need either a plotter to print them or some sort of (gasp) electronical device to make them into pretty pictures. then. of course, you will need to put your boat's location on the map which will require more electronical devices.....GPS.....autopilot..... you can see where this is going. I'm thinking your best "next step" in maps/charts is your local marine store for a chart book. You will want one that is at least water resistant. The non-water-resistant ones tend to get wet andyou tear the edges and poke holes in them at important spots. I've found those "sign here" post-it tabs to be great at marking my position. Use several marked with time to record a sail.
Jun 12, 2010
936
Oday 22 Orleans Marina, NOLA
Marine VHF may indicate water proof (but check the fine print) - waterproof is a good thing.
Only advantage (and it's a good one) to non-portable is antenna size and location. VHF is line-of-sight, so the higher the antenna the more range.
I have a non-portable mounted in the cabin with a masthead antenna. I want to get another, a portable waterproof model that I put in my pocket so if I fall overboard while single handed I can call for help!
Ch 16 is the hailing channel. The CG monitors it as do most (all) other boats with the VHF on.
My mast?
Yep. At the very top.
I have the same problem, so I got a windex (wind direction indicator) that actually slides onto the antenna. Perfect.
