This is copied from a long thread on the Cherubini forum. After discussions with Maine Sail, Stu, and others I am upgrading the battery wiring. Never really had problems with the original five AGMs and all #4 wires but it certainly would not have met ABYC certification. So here is the new wiring with 1/0 cable, battery fuses, new Blue Sea switch, alternator directly to 12v bus bar, and 6v golf cart batteries in the bilge. For your examination and comments.
"Does that look like $370. worth of cable and assorted? I just hope at $5.40 a foot that I got the lengths right. I am not happy with the Blue Seas battery switch. It does not fit flush on the bulkhead, has legs. Maybe I bought the wrong one. The terminal strip will replace one for the mast wiring.
And here it is all wired to the new panel and ready for the boat. Everything is there but the batteries. And the cable from the charger. The 1/0 cable sure looks excessive. Will the next owner be impressed? Lower right is the fuse for the house batteries that will be fifteen feet away in the bilge. You can see that I kept a #4 wire for the direct alternator connection. The combiner wiring is #6. The Link 2000 shunt with all the new 1/0 ground wiring will be just a foot to the right of this panel. There are covers for everything so there are no exposed voltages. Snow is forecast so it might be 2012 before this sees the boat".
