I am pretty sure that mount holds the motor far enough off the transom that it will not be a problem. I have a 2 stroke kicker mount on my Catalina 22 with a 10hp 2 stroke with no wedge. The only problem is that it is too close to the hull in the up position. It makes using the release mechanism a real challenge. It does not interfer with the motor in the down position. I put my Tohatsu on this past weekend but I need to drill a new hole to run the battery cable through so I did not start the break in period. I finish the job this weekend. I would rather take the extra time to do it right. I hate fixing my own jerry rigs.Has anyone succesfully removed the wedge with the Garelick 71091 mount, Tohatsu 9.8, on an O'Day 25?
Hull speed at 1/4 throttle is too fast. How do you go slow?I guess I'd prefer to more on hand than not enough, I'm pleased that fuel con seems to be around 0.5 gal/hr at close to hull speed with 1/4 throttle and plenty in reserve.
Took the new Tohatsu 9.8 25" shaft out for the first time yesterday, motored for an hour to get the running in started.
The good;
Drove the boat at 5.5 knots (GPS) on quater throttle for a total of less than 1/2 gal of fuelHalf throttle increased speed to 6 knots.
Easy start of course oh I do like electric starts.
Easy to tip up don't need to raise mount to get propeller clear of the water, just as well as I don't think I'd want to lift it from in the boat.
The not so good,
Suprisingly noisy, the same may be more than my old 8hp mariner two stroke, vibration at low throttle positions seems to resonate the boat, stiffer motor mount might help.
No way to lock the steering means tie-ing off the tiller and using the motor makes turning slow. I just need to think of a way to tie off the motor, or ignor the manual and reef on the steering stiffnes adjustment bolt.
I got my 6 hp on the boat last weekend. Can't say that I'm crazy about it. Mainly because it is hard to start. I guess I pull the rope twenty times before it sputters to life. I tried all sorts of combinations of chock and throttle but nothing seemed to get a quick start. Once I got it running it seemed to drive the boat ok.RECESS said:I started my break in this past weekend. It seems to run at a higher RPM or it does not handle the rpm vibration as well as my Honda 10.0 did. That is the only down side I have found. It has a slightly different pitch than my Honda but the decibel range seems to be the same. The shifting from forward to neutral and then to reverse was smother than my Honda. The low idle and the ability of the engine to actually work in gear at that range was nothing short of amazing. Being able to maneuver the boat with the screw turning that slow will help greatly. Over all the honeymoon phase is exciting.
Is that the 25 inch shaft?sPk said:I remounted the Tohatsu 9.8 extra long shaft & Garelick mount without the wedge last weekend. I didn't like how far out the motor was and how much leverage it had on the small wedge. I also beefed up the transom with a couple layers of 1/4 plywood epoxied on the inside plus a 1/4 aluminum backing plate. This reallly helped the flexing that was there before. I mounted the Garelick mount direct to the transom where the wedge was. Once I got the motor back on, I was greatly sadened to realize that it wasn't low enough. It is usable, but the cavitation plate is barely in the water. It needs to go down about 5-9" below where the top of the wedge was. That brings it almost down to the waterline on the transom. Also the angle isn't quite right either, it isn't perpendicular to the water. This has been a frustrating project.
If it is. I think something is amiss. I have the 25 inch shaft on the same mount and it goes deep enough. Maybe your mount is not going all the way to the deepest notch? Mine is mounted to the original wedge plate. This pict is before the new mount, but the new mount is attached to the same spot. This can give u an idea of the area and level above the water line they attachment can be.emergpa1 said:Is that the 25 inch shaft?
