any advice on THIS crack???
525
Catalina 320 Tawas Bay Yacht Club
Hey all - I am one of the guys that has said that cracks on the 170 are a fairly minor deal and are pretty easy to fix, but until last year I never actually had a bad one.
Last year I ripped much of the "rudder hump" off the back of the boat so that I could replace the rotted wood that the rudder mount plate screws to. I added a round deck access port so that I could through bolt the rudder instead of using screws again . . . big ordeal, one I am hoping to avoid this year.
This year I fixed a crack under the mast step, the crack was easy enough to fix, but the screws didn't tighten - rot suspected again.
I drilled out the four screw holes to 3/4 inch, my plan is to epoxy an oak dowel into each of the four holes to have something more solid to screw to.
Trouble is that when I drilled out the holes the foam under the wood is wet - I am hoping that the water came from the crack, or from leaking around the screws. In any event my first concern is drying the thing out! As near as I can tell the foam goes full thickness from the mast step to the hull, the foam there is part of a foam box that completely encloses the centerboard trunk. I think the four holes that I drilled are the only way the water is leaving that area. I duct taped a piece of aquarium hose on the end of my shop vac and tried to suck water out, but it seems the water is in the foam - so not much luck.
How long should I let the thing stay open before I try to epoxy the dowel in place? How can I tell where the water was coming from? What other advice do you have?
I am thinking that the main force exerted by the mast is a downward force - so I might cut my dowels good and long and try to bash them into the foam as far as I can to give maximum support.
Any other advice??
Anyone know a real expert that I can call?
john
Mar 2, 2011
489
Compac 14 Charleston, SC
Any other advice??
john
Try Hunter Marine the boat builder. I'm sure they can offer some advice. When my 170 had some similar but less severe repair issues, I opened the drain and let it air out for a few weeks with the trailer jacked way up. Tilt it up as far as possible and prop it up on blocks securely so that all water inside and run aft. I was amazed how much water I drained out. Sounds like you repair plan is well thought out already.
txjim
Sep 4, 2007
154
Hunter 170 Grapevine Lake, TX
A picture would help but I'd consider replacing a large section of the foam with plywood bonded and sealed with epoxy. Cut out the existing foam, fabricate the wood and epoxy it to the hull. Use 8# two-part foam to bed in the wood. Removing larger sections of the foam would also help aid the drying process. (although with 100+ temperatures here in Texas, drying is not a problem!)
I did something similiar to solve a motor mount issue.
-na -NA Anywhere USA
TXJIm hit it on the nailhead. You have to remove the wood. I inserted a new oak or mahoganey piece. Fiberglass mat was used but impregnated with Plexisus. Never use acetone on this boat.
Make sure the cut is angled at the edges 45%. When you start, shoot me a picture.
davecondon@mindspring.com
Crazy Dave
