leaking prop shaft
6,244
S2 9.2a Fairhope Al
I see the prop shaft on my cal 2-27 is leaking.
What is the procedure?
is it leaking at the stuffing box nut...if it is.. it is supposed to leak when under way.....about 2 to 4 drops a min......if it is leaking while at rest it may need tighting a little.....just loosen the locking nut on the stuffing box and tighten the big packing nut a little at a time and wate and see if that stops it...but make sure if you tighten it that it still leaks when under way...if you cant stop the leak you may have to repack the packing nut...there is a good artical in compass marine here on this site that you may need to read to understand what you have...assuming you have no honed skills at this time ....but never fear in time you will be well trained.....good luck...
regards
woody
2,288
C30 Event Horizon Port Aransas
And when Woodster says tighten it a little at a time, he means a half a flat at a time. Then recheck the drip.
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
There is now available a new material for stuffing boxes. Not sure if it is teflon or something else, but when properly adjusted it does not leak.
Jun 6, 2006
6,990
I'd say an 1/8 to a 1/4 turn at a time. You can't back up in this process as once it is compressed and you loosen it it leaks even more. Go slowly.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I don't follow that, Bill. I've loosened a too-tight packing nut before. It can take a little while for the packing to adapt to the new space, I think, but while adjusting, if you over-tighten a bit, I'm sure you can back off.
Have you experienced otherwise? What kind of packing material?
jv
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
My stuffing box which is a traditional one does not leak as I have a grafite based packing that was put in last season by a local prop shop that I deal with. My last trip to block island I ran at 2300 rpm's for 8 hours with no water in the bilge... Nut stays cool to touch.
